My MOSFET amplifier designed for music
Running power dissipation calculations using Mooly's sim for 70W 1KHz, the dissipation for the resistors I've currently got as 1206 film resistors are all well below their rated 0.25W figures. If I went SMD for the power resistors it would be a different story. If it were a problem, I would probably go with mini-MELFs.
Reactions: chermann
Working on collector pour right now. I've already tweaked the layout around Q3/Q5 to allow larger(slightly) heat spreader zones and looking at the relevant derating that comes with that. I've also moved the gate resistors much closer to the MOSFETs.
More soon🙂
Layout with increased heat spreaders for Q3/Q5 and gate resistors now located close to MOSFET gate pads. Heat spreaders and output tracks now have solder mask adjusted to aid heat dissipation. Also included some text.
  • Mooly_Dual_SMD2_1.pdf
Reactions: chermann
