Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
It has been 30 mins, but I keep having bias slowly rise to 178, dial back to 177. Would like to see this stabilize before music plays.
Iq is under 5% deviation from cold to temp. equilibrium
same as for +/-10% rails change, due to possible mains voltage change
in fact, quite possibly under 5%,lazy to check my notes, and who cares ..... once when it is good enough, it is good enough
so.......
Sounds Very nice, steady 1-2 0r less mV offset, bias steady at 176 mV. Heatsink behind devices is 50-52C. Device, by shooting edge reads lower, not much buI seriously doubt its accuracy. I would think device would be hotter, but whatever, amp is playing in grand fashion. I'm about to put a pin in this one after a few on off cycles.
