A Study of DMLs as a Full Range Speaker
My exciters arrived!
Unfortunately, this week is very busy for me and I won't be able to work on the panels before the weekend.
However, based on Eucy's post I realizedthat something must have gone wrong when I copy&pasted the url from my browser:
This is the panels that I got. I am so sorry Christian:
https://www.lowes.com/pd/RevolutionPly-5mm-Poplar-Plywood-Application-as-4-x-8/50121135
And as an additional note, the 4 ft version does not bend as much as depicted in the picture.
Sebastian
how many ply is this poplar panel? thank you.
Had to take some time from playing around with plates to sort out the subwoofer I got hold of. Replaced caps, but no luck, so had to get a new amp. But now finally I can run the plates as intended, and it sounds glorious!
I tried pushing them really hard with a HPF before, but of course that doesn't really give you an accurate impression of how it would sound like in a PA setup. But now with the subwoofer set up even my wife, who usually doesn't have strong opinions about sound quality, was dropping her jaw in awe.
So now I have gotten back in to see what I can achieve with the EPS plates. I got some hide glue and shellac and prepared a 500x330x10mm neopor plate. Seems like obvious choices to try out since that is what is used for instruments and soundboards since ages, and instrument making is one of the few crafts where they haven't gone over to PVA and other synthetic adhesives with many claiming it is inferior acoustically.
Both was a pleasure to work with really. It takes a few minutes to dissolve the glue, but on the other hand it dries completely in a couple of hours.
And the shellac dries extremely quickly...I just had it on and it seem ready to use already. Interestingly the whole plate became a bit convex when applying the shellac to one side, and the stiffness of the plate has increased drastically. Weight before applying the two coatings of hide glue on both sides and shellac on exciter side was 43g, and after it is 63g.y panels to
Will wait for tomorrow and then fix exciters using hide glue as well and post back with results.
I wonder if you had considered pre sealing your panel to minimize the absorption of the shellac? This will result in less added weight along with a little less added stiffness but weight is the major concern here I think. The same could also be done when laminating ply panels.
Reactions: Leob
The canvas panel is still an on going project.
The idea was to eventually add a larger 2mm ply panel to the canvas with a few alterations, for a better response.
But I was not expecting the response from the crate ply !!
This already exceeds my expectations of what I was hoping to achieve.
To be honest , I was leaning more towards an all canvas panel with roll of at about 200hz for best sound.
The larger ply panel does prevent a lot of canvas flapping and buzzing , as pointed out the design so far is more like a ply panel with a canvas surround mounting.
I have made it quite clear that I have problems with the sound of hard rigid ply panels and use methods to reduce this problem , but without damping.
So you can imagine my surprise when I attached the crate ply ,and wondered what the hell was going on !
I thought I had flicked a switch or done something wrong in the setup, which has happened before.
To your questions, the art panel I use is 42cm by 30cm ,this is just as close as I could get to the patent size, but I am sure other sizes should work too.
to be honest I'm not really interested in using any panels below about 100hz , it just doesn't make sense to me anyway, as I prefer the high output from me TLS .
In my last recordings the panel on the right was my art panel , this was the only panel that was reaching 40hz ,the ply strip panel was only going down to about 60hz max.
The art panel plays the double bass very well.
The ply panel on the art panel is about 11inches by 7inches ,this was the largest size I had ,if you want to use larger sizes you can try ?
I'm not sure of the response I would have had if I had used ordinary ply with a few of my alterations ?
As I have said it is an on going experiment , but not a priority for me, as I don't really need the low end that much.
I hope this answers some of your questions.
Steve.
when applying damping in the form of acrylic spray paint you were saying the panel was stiffened in both directions. ad you considered masking off the panel into horizontal strips so you would add desired stiffness to the width but leave the stiffness in the length pretty much unchanged?
Christian (and others) - I highly recommend this glue if you can get it - It's Styrene based - looks line PVA but isn't - adheres to more materials than PVA - quite strong and dries about the same as PVA - I have used it to glue exciters to panels instead of epoxy and it's worked well
Cheers
Eucy
is this a harder glue than pva? thanks.
Leob.
I have used pva to glue my exciters on all of my panels including aluminium , some have been firmly stuck for 10years.
Although I am happy to try all sorts of panel materials and glue, eps and pva are my personal favourite, and have been for over 10years now.
I have not made any comparisons but I think the low quality crate ply might come in as a close second ?
The recordings don't really do the sound any justice , but give an impression of the general sound available.
So far the pva is still stuck to the polypropylene, I have given it a few tuggs now and again to check it is still firm.
But two good signs it is holding well is no buzzing and a good extended frequency response.
Steve.
Steve I understand why fiber glass cannot be used on Styrene foam ok so why not just make fiber glass skins then prime the fiber glass skins so what ever glue you want will stick to it and then bond the skin(s) to the foam core, or is there a problem I am missing?
Christian.
It is interesting to see your plots have an upwards trend at 20k.
the three plots have the peak at about 10k ,with the dips (cancellations) before and after, this I believe is caused by the exciter coil area, which I am always banging on about 😁
Which no one seems to pay any attention too ?
what is also interesting is the hump in the response in the 2k and 3k area , this I believe is the exciter noise being reflected back from the walls, which is not in the red outside plot .
this happens in various degrees and frequencies depending on panel materials ?
Personally I would bring in my TLS at the 300hz point ,producing a slow roll off similar to the room response idea ?
I would roll off the panel at about 100hz or so depending on listening tests ?
I would also recommend using a material similar to the cheap crate material, as this is a performance changer !
Steve.
the crate material was best guessed as a three ply poplar or similar? with what thickness? Approx. 3/16"?
Hi Christian:
I think you are correct wrt the poplar ply - It will be hard to surpass with more complicated and costly materials.
Shellac = French Polishing yes.
I'm far from an expert in this but I have achieved quite good results with a very basic approach. I'm also after a satin finish not a mirror gloss one.
One issue with poplar is that it has a very bland finish - it's very pale and the grain pattern can be uninspiring. I initially only had Gold/Orange shellac and I thought that it would end up too yellow by itself so I tried first applying a very light stain to the ply which worked OK but I think could be avoided by using a mix of Garnet (dark) and Gold shellac instead.
So I bought flake shellac in gold, garnet and platina (blonde). The flakes keep indefinitely if stored in a dry cool place unlike premixed shellac.
3:1 Alcohol / Shellac mix by weight is a good middle mix (just a bit thinner that a "2lb cut' but you can try different ratios. I thinned out the first coat somewhat for penetration.
I didn't do any grain filling - I relied on judicious sanding back between coats which worked OK - I wanted to avoid too much junk in the panel and I don't mind a trace of grain showing. One luthier uses West System epoxy to seal the back and sides of open grained woods but not the soundboard (
Application- I have tried the traditional cloth method but it's difficult and takes much practice. I found that with practice I could brush it on quite well. When brushing you have to be quick and only brush with a forward or backwards motion, not both, work from one end to the other as evenly as possible across the panel and avoid going back over wet areas. Apply enough to the brush to get a wet finish and as soon as you start to use the brush load up - dip again and go - it's important to get a flow going so you end up with an even wet coat. I used a 30mm wide brush and stored it in a jar of alcohol between coats.
I haven't tried spraying, but it seem to be an ideal candidate as it's very thin and is easily cleaned out afterwards. Maybe I would revert to spraying if my panels were larger - long narrow panels would still be easily paintable however, it's when they start getting wider that makes it a bit more difficult, but you could probably just use a wider brush
It dries very quickly - I help it along with a heat gun on a low setting waved over it if I'm in a hurry.. make sure it's not dusty if you do that.
You can sand back after each coat dries. I use worn 240 grit paper or fine wet and dry paper.
I applied 4 coats sanding between each, and to remove the gloss after the final coat (which after 4 coats is still a bit uneven) I rub down with grade 0000 wire wool which blends the finish and gives a satin look.
I found the shellac finish is surprisingly tough - tougher I think than acrylic lacquer, so I believe it's and excellent way to finish timber in general - I applied it also to some pine feature strips and it turned out great. It's only drawback is sensitivity to moisture on tables etc but that doesn't apply in this case. It's stood the test of time on musical instruments so that's good enough for me.
Oil - I used no oil - I haven't had any issues with the finish on vibrating panels so I can't see the need for oil.
Go for it Christian 👍
Good Luck
Eucy
So is the shellac finish simply foe aesthetics or is it intended as a stiffening skin or is it both? Thanks
Eucy and Christian.
Personally, I would be more interested in the panel size, and how to get the correct rigidity and flexibility for that panel size.
As with my small card panels.
I used neat pva to glue the two 0.5mm cards together and then coated with 50x50 mix pva water.
This gave the card a very good performance.
The large 5mm XPS has a coating (layer) of epoxy but I can still easily compress this panel between my fingers.
The xps now has a good response up to 20k.
Having the glue (layer) in the middle of the card gives the strength a and flexibility it needs to stop the card breaking up under pressure.
I was hoping to use this method with 0.5mm veneer but got put off by all the types of veneer and postage.
So compression isn't necessarily a problem.
But rigidity can be a problem, in my experience.
Steve.
Steve with respect to your thin card panels it would be very helpful for those (in world wide locations) who may want to replicate your work if you could provide some basic information about the card stock A visit to a art supply shop could provide information as to card stock thickness weight /stiffness/density etc. from paper suppliers so that others can purchase material to replicate your results. For those like me I can go down to the recycle bins in my apartment bldg and pick out what ever samples there which appeal to me but I too might like to make one just like yours so I have a reference. At the beginning of a building journey it is always nice to have a reference. Thanks
Doesn't it feel great having a clue regarding what should actually happen to the modes when you move the constraints?
As far as what you should be looking for, well, that's the big question right?
Two notes:
  • Regarding the last mode you showed (and below): That is indeed a valid mode but it is not a "transverse" mode. That is, its displacements are in the X and Y direction, and not the Z. You can see this if you use the animation tool. I suppose this mode might radiate from the sides a little bit, but I think you should basically ignore this mode and any others of this sort. These modes are often fairly conspicuous once you have seen them a few times, due to the relative scarcity of blue in them. I don't think they contribute anything meaningful to the sound
@Eric, @homeswinghome, et al,
I've been trying to get my teeth into LISA FEA, thanks for the very helpful guides, Eric. I've been having fun modelling different shapes with different properties.
Two questions:
1. How would I model a panel assembled from different materials, for example a polycarb plate with a hole in it, and an aluminium disc inside that hole on which the driver is mounted.
2. How would I use LISA to find the coincident frequencies of different panels? None of the equations I use give me consistent or believable results. I've been having arguments with ChatGPT regarding this, and we've eventually agreed to disagree....
I was initially thinking of making a 6x9inch veneer panel similar to my card panels.
But instead of crossing the grains maybe I should have them going in the same direction using pva in the centre for flexibility.
But if stiffening is needed the use of more pva on the outside is possible or a thin scraping of epoxy similar to how it was done to the guitar in the video.
A very thin coating.
Steve.
Steve what about a veneer in a pie pattern made up of wedges where the grain orientation alternates between straight from outside to centre to across the pie shape? in this way a three layer lamimate could be made where centre disk is offset by one slice from the top and bottom layers?
As usual after being away for a while, I turn on the system to see if it still sounds good.
Wondering if I'd been fooling myself as to how good the sound was ?
Once again I was pleased to hear very nice sounds.
I played this track off of a cd I'd never listened to all the way through (it's not really to my taste) so I was surprised to be very involved in the sound and the music .
The recording does not do the the sound in the room justice , but you can get an idea of the detail in her voice and the electronic echo fading into the background.
Just remembered I've got to send it to the computer and zip it 🙄
But in the meantime, this is a picture of the slight warp in this panel, not that bad considering it was 4 strips of badly warped crate ply glued together 😁
I'm not that bothered by slight warping.
And i have done nothing to this panel yet, so no coating ,no dust cone in the centre ,no weights , nothing!
Steve.
Steve what is overall dimension for this panel along with the thickness please? The Shirley Horn clip does sound good thanks. Would you say that your double 0.5 mm small card panels (I think they were around 6 - 8" dia ?) do they sound like this?
christian .
the affect the egg whites have on a thick heavy ply may not be that much ? but the affect on a 1mm card or veneer can be quite significant ,
i use pva on my small card and veneer panels and have experimented with epoxy ,to give the panels a bit of body .
they flap around too much without this coating, egg whites might be another option ? especially if it has a reduced weight when dry ?
i have just finished another packet of cereal, the box is 19cm x30cm this seems a good size to start with.
i think i will glue the two .5mm together with pva as usual as the egg whites will probably just soak away into the panel.
so i will end up with a 1mm x 19cmx30cm panel with pva in the middle and an egg whites coating.
i may do some tests with a scrap piece first and see how it goes.
steve.
Steve are you bonding the package label sides together so the sized and print surfaces (probably provide some additional stiffness) are in the middle o the ply? then normally two full strength coats of PVA on the exciter side of the panel and two half strength coats of PVA in the front side? Have I got the recipe correct? Does exact panel size make much difference? What would you normally make the size format ratio? I think you mentioned 6x9 inches? I want to build a panel like this first to see what it will sound like. Thanks for answering my questions.
I've been playing with DML's for about fifteen years.
It is my opinion that one exciter per panel yields the best results.
Here is a photo of a prototype pair. I used corrugated plastic for panels. (Not the best material.)
stacked four panels isolated from each other. One exciter per panel. All panels were suspended
with duct tape.
They sounded pretty good and had plenty of volume. Bass was decent to 70hz.
Reactions: moray james
Leob.
This picture which I think I posted before?,is of one of johnnogs proplex 2ft panels, with the exciter just plonked in the centre.
With no eq or damping but with an excellent response plot.
Strangely I can only hear clean sounds with no ringing 🤗
The tectonic link explains why.
Under ,how dml works.
The last computer animation at the bottom clearly shows the impulse in the centre of the panel with the dml actions there after.
Steve.
https://tectonicproaudio.com/about-the-technology/
wow that is amazingly smooth response so this is full range and goes down to what 40Hz.? what size would the material need to be to go down to only 100 Hz.? What material is proplex and how does it fair so far as efficiency goes and what exciter was used? Thanks. (does it sound as good as it looks?)
hkguy6
had a spare half hour, so made this very quick recording of the 1cm eps low grade.
i was holding the phone between the two panels playing fullrange, with no subs .
hope it sounds OK.
steve
Steve these sound wonderful with lots of energy but they are well composed. so is this the white soft ps foam or the higher density expanded foam? what size were these panels? thanks.
Mylar Drafting Film
Technical types among us will know of mylar Drafting Film...a much thicker version of cling wrap coated to receive ink.
I'm wondering if anyone has tried it as an alternative to a canvas panel?
I was co founder of Higwood Audio, we developed a planar magnetic travelling wave transducer using 150 gage HS Mylar it used wave traps at the outer edges and acoustic filter/loading across the panel it was driven by a single layer voice coil 1.25" dia and had a small centrally mounted dust cap to extend response. A heavier diaphragm would have been nice. We also terminated such diaphragms with polyester silk screen mesh which has very high loss and is available in a wide variety of weights. Some damping was added to the silk screen.
Hi Moray
I'm very interested in this... Can you please provide more detailed info on the construction
Eucy
Edit...I found an article and realised I also had the patent downloaded... Will re-read with interest
Our patent was applied for just a short time before the original Manger patent and blocked them. Manger contacted us asking if they could licence the technology or failing that suggested the two companies merge. We declined both options, at that time we were just too busy with a start up company. Our speakers were marketed under the Sumo Audio name. Things did not work out with Sumo which was too bad and we merged with Meitner Audio in Montreal. The speakers were then called the Melior 1and 2 along with an in wall speaker and some hybrid models but those were after I left the business Ed still lives in Calgary and runs EMM Labs with his son.
The Highwood panel had the voice coil placed in the centre of the panel for a specific reason, we did not use a spider on our motor rather we use a magnetic fluid in the v gap a a liquid bearing to replace the spider. This necessitated keeping tension on the vc as even as possible during motion. The DuPont Mylar HS is a biaxially oriented film which helped keep the vc stable. Hope this helps and is of interest.
