Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
aluminum strips are ready and around it.
maybe shield the transformers once, it's fine for now.
Hello I would like to operate my Denafrips Pontus 2 via the I2S interface with a streamer IAN Canada? Which parts are needed ? A clock is not needed?
#48B. PurePi II 5V+3.3V ultracapacitor/LifePO4​
#17B. HdmiPi Pro II Flagship HDMI transport interface​
https://iancanada.ca/products/3-2v-lifepo4-battery-cells
https://iancanada.ca/products/1d-fi...h-isolator-re-clocker-and-low-phase-noise-xos
https://iancanada.ca/products/49b-monitorpi-pro-integrated-control-center-and-signal-analyzer
if you use the flagship HDMI board, you should also use the Q7
I would also recommenbd the MonitorPiPro for Q7 configuration and debugging
Audiophonics doesn't sell 25mm long standoffs yet, and the documentation (of the UcConditioner) doesn't mention them at all, not the M size.
Are they M2.5 or M3?
The product page on Ian Canada's shop site mention to get the standoffs, but that page doesn't mention the size as well, only length.
Hello,
I just want to share my experience in the case that someone else has the same situation.
So setup is: RPI4 -> FifoPiMa -> AK4497
With default PCM setting of dac 32bit MSB justified I could not get sound over 88.2K sample rate.
while with 16/24bit I2S compatible mode (DIF[2:0]=011) it plays all formats up to 384K.
Configured dtlayer is hifiberry-dacplus
Hi @pkonstantinidis
Just trying to remember your setup, but did you not use a 9v AC supply for your linearPi+UcCon. combo configured in 5V?
This voltage would easy my build because I then could use a single transformer, so just asking. Ian actually recommend 6v AC in the troubleshooting blog at his website.
@SimonJ Was it not you that have this experience regarding the use of 6v instead of 9v due to a blown fuse?
Anybody else had issues with blown fuses used with the 9v AC input?
Regards Mikkel
I had an issue with a fuse blowing when the voltage was above 6V. The fuse would blow at the end of charging UcCond, and just after it turned the "conditioning" LED ON. Interestingly I have several such setups and the one that was generating the problem was LinearPi v1. The rest are LinearPi II and same as zabloc - no problem for several months.
Reactions: miklau
Hi @pkonstantinidis
Regards Mikkel
I have used an AC transformer with 3 secondary outputs at 9V each (max 2.5A). Two secondaries power two LinearPi boards and the third secondary drives the Salas L-adapter.
I hope I have clarified how my setup is. 😉
Reactions: miklau
5v 3,3v PurePi 1, isolatorPI II and FifoPi Ma.
according to the manual, the isolator must be in master mode, the FifoPi Ma jumpers (on) J4 1-2 and 3-4 to share Paspberry Pi power, in this way the isolator II does not need to have power on J1 5/6 volts.
is it possible to supply the isolator II with 5 volts J1 (or 3.3v) by not connecting the jumpers J4 1-2 and 3-4 of the FifoPi Ma?
ps, I also use the 3.3v clean side FifoPi Ma.
Hi @pkonstantinidis
Regards Mikkel
My issue was with UCpure where the transformer voltage was too high and in the end damaged the UcPure
Reactions: miklau
