Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
@GKTAUDIO
So this is made from just a flat strip of aluminum or steel, bent, drilled, slotted? I though it might have been an odd the shelf part for something else that was repurchased as a potentiometer mount.
I'll probably go with 3D printed route out vs metal fab for simplicity+customizable, but a repurposed off the shelf part would be ideal.
[Edit]: Thanks Zen Mod, that's a good suggestion. I'll check online at local big box stores (Lowes, Home Depot in my neck of the woods) for lumber bracketry that works.
[2nd Edit]: Well, I searched for "slotted L bracket" online and found lots of good options for cheap. Amazon had lots of options.
Reactions: GKTAUDIO
I would not bother with a slot, just measure your hole location properly. You could drill an oversized hole and use flat washers if you don't have accurate means of measuring. You could use aluminum, but it must be a malleable type or it will crack at a 90 degree bend. Thin steel is easier in this regard.
Not aware of any off-the-shelf right angle, slotted pot brackets, but it seems there should be some available. Since I have a pretty good metalworking shop and tools, and no 3d printer (or skills), I'd whip up a couple brackets in metal rather than search and wait. Go with what you have available!
Oh, and ZM's idea is also a good one - you can get galvanized stud hanger brackets from a hardware store and cut them down, then drill the holes where you want them. They will have screw holes already, but likely not where you need them. Or, just buy some flat bar steel and bend/drill. Sounds like the 3d printing is more in your wheelhouse though.
Reactions: Ixnay
20VA per channel is more than enough
bigger just means bigger risk of interference
Thank you for that info. I had purchased both 50VA and 20VA and was going with the incorrect "bigger is better" approach for the SE version.
Can you explain (or point me in the right direction) best way to shield a terminal block, or other preferred approaches to minimize EMI? All I recall from the build guide from 6L6, it just mentions placement of transformer and wiring.
As I wander about my shop, there are a few different L shaped metal brackets and such. At the hardware store, they sell them ready made and different sizes, although I would still cut the bottom of the L to a shorter length and drill my own hole. Probably would end up drilling for the shaft as well. All in all, if you have a vise and a strip of steel, the problem solves itself.
@Zen Mod
Ahh, now I see. Shield is to prevent "ZAP", not EMI. Thank you!
Reactions: delecoy
I usually build my own design/thinking when it comes to a chassis, but then I see this and am more impressed than usual. Very nice layout.
My only complaint is the top/bottom plates don't fasten to the back plate. The bottom plate sags and leaves a gap when weighed down with hardware. A couple of L-brackets would fix it, but those should be included and holes should come pre-drilled IMO.
Reactions: Ixnay
Thanks for mentioning that. I am a real stickler for having a very solid chassis to start with. It is not unusual for me to add bracing, or as you mentioned, brackets if needed to attach one plate to another. I agree with you about that sort of thing to be included, especially if it is a front panel. Yes the rear panel too, but the front panel would be harder to do by way of DIY. I suppose that you could add a thick bar to the top panel and then run rods down to the bottom panel, but really?
