Keratherm is good. I find it very much analogic to low profile rubbers: pleasure level is high, but so is risk and consequence of ripping.
If you want the very best locking method use this. Will not damage and has the greatest work holding capability.As long as you remember to use a split washer between the screw and the fender washer
https://www.mcmaster.com/products/belleville-washers/belleville-spring-lock-washers/
Used in Aerospace and Racing Applications.
A fellow fan... good to see 🙂^I also am a fan of belleville washers.
Don't wear out and does no damage. There are also belleville springs. I used them to make Flight Control Data simulators. The first that actually worked and could return to zero.A fellow fan... good to see
And VW bug engines. They have dozens of metric wavy spring washers....https://www.mcmaster.com/products/belleville-washers/belleville-spring-lock-washers/
Jet engines old and new as well. A good idea to not create anymore failure modes internally.
Why are splits and deformed feathers still used is beyoud me.
Schlubs of the world, UNITE!... This looks like a great kit for a schlub like me..
The current kit includes flat M3 washers. Feel free to upgrade if you wish. That's what DIY is all about!
Donde esta El Kit?
Can't update vaporware.
Watch the store instead of complaing in public. It will be there soon enough.
ACA+ kits hit the store this morning. Pearl 3 Phono kits dropped this afternoon....
It can't be much longer now. The anticipation is a roller coaster ride of endorphins every time I go to the store site. I love it...
What a great time to be jumping in to this wonderfull adventure in diyaudio!
A sincere thank you to everyone involved in making this F5m project happen!
Yeah... a very nice effort from all involved.
Plus, you don't see this kind of support very often.... it made me feel very special.... Thank you, Nelson.
Hopefully everyone will take that "When all else fails" part very seriously.
I think it should read "If" instead of "When."
I expect the success rate will be quite high, the failure rate extremely low.
- F5m kit
