@carsten.wit are you willing to share the file for the 3D printed "chassis"? Looks really good!
Thank you Carsten for the inspiration via your design. 😊 👍
ACA mini making music (½ minute video)
DIY speakers from years back... using Nokia LP 80 3" and Audax AW010 drivers.What are those speakers?
can drive a bigger ones too..have fun ,nice buildDIY speakers from years back... using Nokia LP 80 3" and Audax AW010 drivers.
yes, this was just for testing...can drive a bigger ones too..
As far as I can tell (coming through my MacBook) they sound quite nice.DIY speakers from years back... using Nokia LP 80 3" and Audax AW010 drivers.
Yes, they really do. The original design had just a cap for the tweeter, but then I copied the crossover of a similar design using an inductor and resistor, and it did wonders to the design. I’ve made a few of these for friends and family, and they work really well on windowsills or set close to walls. But seems like the 3” drivers are pretty much extinct now. The little brace at the bottom is copied from ProAc - I like the looks . 😊they sound quite nice
Has anyone used ACA Minis to drive LXMinis? I realize those speakers are meant to be driven with beefier amps, but I'm curious to hear if it's been done.
Hello,
maybe it's a bit of a stupid question, but - if Vb in my ACA mini is 0 can I assume that Q3 and/or Q4 are dead?
thanks for the help.
cheers
Flo
cheers
Flo
Very unlikely. Much more probable is Q1/Q2 are passing insufficient current to develop the needed gate/source voltage on the output FET's. Are you using the correct input FET's and what gate/source voltage can you achieve on the output FET's?
all FET's are the "orignal" FET's wich came with the kit. fun fact - it did work already :-(
Q3 3,511V
Q4 0V
Q3 3,511V
Q4 0V
0V across Q4 gate/source shows a problem. Are you sure the preset is turned to the correct end? Assuming it is then switch OFF and measure on ohms range between gate and source. This is just to make sure there is no short there.
Also what is the DC voltage at the amp output before the speaker coupling cap. It should be about 12 volts.
okay, strange. P2 off one channel was set to the most counter clock position. i turned it clockwise.
now i have Q4 G/S ~ 4V
i set VB to 0,3V and V0 to 11,5V.
another interessting thin is -> the amp is now running for about 1 hour on my desk without anything attached. the heat sinks of the "functioning" channel are warm as they have been already in the past. the others stay still cold.
That all sounds OK. I can't say which way to turn the presets as I am just working off the circuit diagram but turning the wiper so it connects to the drain/s of Q1 and Q2 is the position that gives highest bias current.okay, strange. P2 off one channel was set to the most counter clock position. i turned it clockwise.
Are you saying there is a problem in this other channel? Is the 12 volt reading OK at the output?another interessting thin is -> the amp is now running for about 1 hour on my desk without anything attached. the heat sinks of the "functioning" channel are warm as they have been already in the past. the others stay still cold.
Seeing some clear photos of the top and bottom would be helpful. Are the Q3 and Q4 transistor screws snug enough to make good contact with the heatsinks?
Does the power indicator LED pulse at all?
- DIY ACA mini
