load regulation
Show me a current source which works with 0,6 V ..
Here's one. It "works with 0,6 V" both in SPICE simulation, and in the real world on the lab bench.
_
Reactions: lineup
Yes, I did not consider a mirror, only "classical" current sources.
In some very famous and popular threads about regulators here a JFET is used as current source
with less than a single Vbe drop, there is a source resistor in series. I am not convinced this works.
I will not do such a thing, the schematic from the first post is fundamentally wrong, there is no current path to ensure the blocking of the series transistor, which results in a very poor quality dynamic behavior.
I also think the schematic in post#1 is no good.
There are a number of improvements to make.
Several have been mentioned in this thread.
Best would be a totally new design 🙂
With some optimisation it was 2-3mV and under 1mV with darlington. The optimisation includes compensation too, but this schematic is made wit different transistors, available in library.
Also the output currents are different.
În fact on that version the difference was 72mV but this is not important, more important is that in the same analize you have the same schematic and values, version with simple resistor and version with current mirror. Is not correct to compare the schematic from first posts made with different transistors and in a different simulator whit this.
