The ZD25-Mini (aka. the Holy Grail Follower).
The ZD25 is an amplifier I built that is similar to the Pass Labs XA25, that was discussed in the "F4 Beast Builders" thread: https://www.diyaudio.com/community/threads/f4-beast-builders.300233/post-4907053.
The ZD25-Mini is a simplified, lower power implementation of the ZD25 output stage.
Implementation:
The amplifier combines three experiments (for me):
This is a FirstWatt scale amplifier with a PCB that conforms to the diyAudio UMS and can operate with either linear or switching power supplies with +/-23V to +/-27V rails. The output stage FETs are not degenerated which has the benefits described in the Nelson Pass article "Art of the Square Law": https://firstwatt.com/pdf/art_the_square_law.pdf.
Specifications: (as configured Jan 16, 2024)
Implementation:
- The optocoupler bias circuit described in post #1.
- Using a opa551 high voltage opamp for the front end, thanks to EUVLs “The M2 Output Stage in Class A/B, and maybe a Power WHAMMY?” thread
- Use of inexpensive SMPS for the power supplies. A regular linear supply would be fine, but cost more and be heavier. More about this later.
- Voltage Gain: 22dB
- Global Feedback: 12dB
- Distortion: THD <0.01% at 1W, THD < .05% at 25W
- Input Impedance: 46K
- Damping Factor: 120
- Frequency Response: 1Hz to -3dB @270 kHz.
- Power Dissipation: 60W-70W per channel
- Noise: below 100uV
Performance:
Here are distortion spectra for 1kHz into an 8R load at 1W, 16W and 25W:
Here are Watt sweeps for 1kHz into 8 Ohms, and 4 Ohms, and a frequency sweep for 1 Watt into 8 Ohms.
And here is the 8Vpp, 50kHz square wave response: Opamp output (yellow), Amp output (bluje):
Here is the dual SMPS and chassis wiring:
I tried IRFP140/9140 and IRFP240/9240. Both exhibited the IRF P-channel problems that Nelson has described in the past.
I happened to have the Fairchild FQA28N15 and FQA36P15 FETs in stock so I tried them and they look very good for this output stage.
I have on order some IXYS IXTQ36N30P and IXTQ36P15P FETs that I will also try.
I really want to use FETs that are in current production.
Do you have other suggestions?
https://www.diyaudio.com/community/threads/complementary-power-mosfets.378024/post-6889027
Only for your reference.
Patrick
Patrick
Looking good!
Current production parts, yes please. 👍
The IXTQ36P15P look good for the P channel; check out the IXTQ75N10P for the N channel.
The OPA445 is another high voltage, high drive opamp to try.
The opa445 would be good if I needed rail voltages over +/-30V. Otherwise it has a lower gain bandwidth product.
I preferred the IXTQ36N30P partially based on its lower Crss. I don't know if the higher transconductance of the IXTQ75N10P would be better or not.
What I have posted so far is work in progress. There are many component options parameter values that can be tuned.
What I found amazing is how the amplifier sounds and measures. I keep rechecking my instrumentation because the measurements seem unbelievable.
In future posts, there are three major subtopics to discuss:
- Performance of the magic-modified optocoupler bias circuit. Hint: It works as predicted in simulations.
- Performance of the opamp front-end.
- Performance of the SMPS supplies. Hint: No filters (except to RC filter at opamp) and I cannot detect SMPS noise.
The IXTQ36N30P is certainly an interesting part, looks like a good alternative to the IRFP048 for a few applications. It will require adjustments for the higher Vgs. I may buy a tube to give them a try.
Pretty impressive that no SMPS noise is detected sans filtering. Those appear to be spec’d at 200mV p-p for noise. Assuming that’s just the symmetry and PSRR at play?
Yes, I the SMPS noise is very low without serious filtering.
- Output stage has good PSRR
- RC filters at the opamp
- Careful star grounding
- opamp common-mode rejection by RCA shield ground-loop breaker resistor.
It would be interesting to see the distortion of the output stage alone, without the opamp.
Afterall that is supposed to be the purpose of the exercise, not ?
Patrick
Patrick
- The Holy Grail Follower Output Stage
