A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Thanks @dddac
So this way, right? V-violet (15), w- white (0), V- violet(15).
Disabled Account
Joined 2002
Hello,
I meshed up the choke numbers. I have a few LL2771 ( 5 or so), have two LL2733.
But Doede was talking about the LL2773 which is real high current choke.
If you ask Lundahl to adjust the airgap to 425 mA ( little margin) you will need for the new DDDAC you will get a 750mH with 0,44 ohm dcr.
I wil ask Doede if he likes to try a 400mA LL2771 which will have lots of mH but also 2,8 ohm dcr.
Greetings Eduard
P.s chokes are not that expensive , they last for ages as well
I hadnt seen your message and went ahead as per your previous suggestion. I checked the voltage without connecting the supply to the dac first. All worked fine actually. I could use the trimmer to bring the voltage up to 12.5V and it has been 30minutes since i first powered it on and it has maintained the required voltage properly. Nothing overheating as well. Then i connected the psu to the dac and it played fine without any issues. Should i correct anything now? Do i need to shutdown the psu?
