I have similar power button, maybe you can see in this diagram what you have to do
Thanks! But I still find it confusing as both our pictures show a device and a power supply, whereas I only have two wires available from J5 on the PurePi II. This J5 seems to have both functions: it is the device that should be turned on, but also provides 5V power.
Are you using your button as an external on/off for a PurePi?
done 👍 thx
I solved it by powering the button light continuously from the 5V RPi PS. And pushing the button takes the PurePi out of standby.
Hi everyone,
I am really struggling to solder Maxwell ultra capacitor to UCConditioner 3.3V. I have not used solder before. I'm scared i'll end up destroying the UCConditioner board. Is there an alternative to soldering, like some kind of conductive glue that hardens.
Thanks in advance.
Thanks in advance.
If you are not experienced in soldering, I would recommend you try a few basic things first to practice and get a feel for your iron and the technique. Maybe a simple first timer Pi kit that lets you solder things after breadboarding. this way you make something useful if you succeed and if not you are not out of pocket much.
That being said, having an iron that gets hot enough is important as are a clean iron head and use of flux. 350c should be sufficient heat to do a quick clean job of it. Apply flux to your intended work area, load the iron tip with some solder, apply the iron to the joint area for a few seconds and slowly feed the solder into the joint while still keeping the iron in place. When you finish it should be a nice shiny looking joint, not dull.
Hope this helps. 🙂
Hope this helps. 🙂
No PLL required if DAC also runs on 10MHz clock. Many DACs (and I2S sources) work on a fixed ratio between MCK and FS (typically MCK=256fs) and only specify a sampling rate range (eg. 30kHz to 216kHz). With 10MHz MCK the sampling rate will be about 39062.5Hz.10MHz is not an audio frequency. How do you ran a streamer with a 10M clock, by a PLL?
Based on this priciple my USB-to-I2S board has been tested to work with DACs and ADCs that use a 10MHz clocks. There are plenty of ultra-low phase noise 10MHz clocks available from decomissioned 4G network equipment.
Telecom timing is concerned with long term frequency stability: wander. For audio you need to optimise short term stability: jitter. One does not necessarily guarantee the other.
No i am using this switch as it is intended, as a full power on switch from the mains to power all transformers. Mains live/neutral and transformers live/neutral total four (4) connections/wires. My switch is 220V AC.Thanks! But I still find it confusing as both our pictures show a device and a power supply, whereas I only have two wires available from J5 on the PurePi II. This J5 seems to have both functions: it is the device that should be turned on, but also provides 5V power.
@m17xr2b , I would double check the power connections and take out the crystals and confirm the 3.3V at the crystal sockets. You have to worry about the crystal clocks first before worrying about the incoming PCM signals. I believe it should show the two clocks, otherwise, nothing would work.My Group Buy order arrived and put the Q7 to work. Unfortunately the MonitorPI shows NOSIG. Is there any extra config required when used just for re clocking purposes without a PI?
My setup is USB input -> PCM63 MIRO DAC input connected via LRK,BLK and DATA, working fine.
Rerouted the three connections + ground to J1 as the manual specified 40-Data, 35-LRK, 12-BLK. No signal. Tried a different I2S source via LAN, same issue but works fine connected directly to the DAC.
Replaced the clocks with SCPures, no difference. Tried some options in the MonitorPI and nothing helped.
I2S, Power and Empty LEDs lit on the board.
Any ideas? Couldn't find any info on the WRONG info displayed on the Monitor PI:
Video of monitorPI:
I have a 10M rubidium atomic clock, and I assure you that it has significantly improved the sound quality of the Audio GD dac (accusilicon), I wanted to integrate the qualities of the reference clock also into the streamer. I noticed an IanCanada SinePi board that accepts external clocks, but I don't understand if it can work with an external 10M. Does anyone have experience with the 10M and can give me advice?No PLL required if DAC also runs on 10MHz clock. Many DACs (and I2S sources) work on a fixed ratio between MCK and FS (typically MCK=256fs) and only specify a sampling rate range (eg. 30kHz to 216kHz). With 10MHz MCK the sampling rate will be about 39062.5Hz.
Thank you
Yep, that was the culprit, a faulty connection on the 3.3V rail. Once that was fixed it worked as expected. Your intuition was on point.@m17xr2b , I would double check the power connections and take out the crystals and confirm the 3.3V at the crystal sockets. You have to worry about the crystal clocks first before worrying about the incoming PCM signals. I believe it should show the two clocks, otherwise, nothing would work.
Hello,
Sounds so risky faulty connections with supercaps.
Of course a good idea to at least use different colours for each polarity.
Greetings Eduard
Greetings Eduard
Audiophiles can use this as well:
https://www.mutec-net.com/product_ref_10.php
Thank you
If you play a 192KHz 32bit music, the SCK frequency will be 12.2880MHz, how can you run your DAC with a 10MHz MCLK?
Are you using a ASRC re-sampling the music or generate a 24.5760MHz/49.1520MHz from the 10MHz OCXO by a PLL?
Ian
Unfortunately I have basic knowledge. however the DAC is an audio gd r8 HE mkII, but I also have a gustard x26 pro, and the use of the 10M softens the sound a lot, as well as making the sound image wider and clearer.
I think they both work async
Gianluca
Gianluca
- Digital Line Level
- Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
