Amp Camp Amp - ACA
Frankly, I do not have an archive of soldering jobs, so I can only dig in my stock and make a photo of some old prototype
My advice was quite sincere - without reliable assembly and soldering you may expect any kind of “unexplainable” failures. I am saying that as someone who spent 40+ years in electrical engineering and electronic design and who has assembled, soldered and tested about 4000 PCB boards. Just an advice.
And what does this prove?
That you are better than Joe Blow?
Who cares?
This is DIY as far as I know.
You better start a new thread offering professional advice how to best solder DIY kits, don't pollute the conversation here.
is it just my ZMEngrish?
anyway, I don't care
when I see awful soldering job, I don't have a problem to say so, and I'm not expecting Solderer getting that as personal characterization and insult
if contrary, well, not my problem
whenever I was prompted by someone to do better work, it just did benefit
Reactions: PMA
in post 11916 i implement the ACA amp boards in a Apple G3.
here:
now the empty ACA housing (very small- just 60mm high) has to be a linear power supply with the given Trafo 160VA 18VAC one Winding with 8,88A.
CRC and caps what i got and have.
trafo- rectifier - CRC (on board, changeable) - output
CRC 2x12mF / 3x0,22R / 2x33mF
2x 22k Bleeder resistor and a green led
no load 24,61Volts
under load with 5 amps --> 20,80Volt
holly *%§"§ it is very small and compact..never did this before😳
chris
Hi, I'm looking for advice on a replacement switch for this kit. I understand that the original switch is rated: 6A @ 125 VAC, 3A @ 250 VAC. How important is it to keep to those values? Would a rated 3A @ 250 VAC/5A @ 125VAC work fine too? Sorry if this is a stupid question.
Upon closer inspection it looks like 5/5/.1 . It does seem strange, but there it is. My only guess is that the switch relies on relatively light spring tension to make and break contact, and there is a greater propensity to arc/fuse with DC current than with AC. But a factor of 50 does seem extreme. Even with the 5A rating, I wouldn't be comfortable using this switch for mains voltage. I'm using ut to activate a 24V relay.
