Brian Steele's tapped horn with Skar Audio DDX12
What would be a proper design for these? Let’s Say ~ 30/35 - 90/105 hz or so .. any size/shape/fun
Again, using the T/S max flat alignment math I've posted & 2*Qts to approximate inductance, thermal power distortion:
Vented net volume (Vb) (L) = 20*22.3*.64^3.3 = 102.3 L
Vented box tuning (Fb) (Hz) = 0.42*38.47*0.64^-0.96 = ~24.8 Hz
F3 (Hz) = Fs*0.28*0.64^-1.4 = 20.12 Hz actually F6
Fhm = 2*38.47/0.64 = 120.22 Hz driver offset
~24.8 Hz/102.3 L TP >115 dB/~22-90 Hz/2pi/200 W
~24.8 Hz/102.3 L TH >115 dB/~22-165 Hz/2pi/600 W
Trade-off of course is a 3.46:1 CR, so would have to experiment to find if these Xmax limited sims are reasonable, but 'fast' transients will in theory be OK @ 1.0 kW.
Regardless, these are just to give some reliable math examples to adapt/expand WRT Fb, Fhm, net Vb.
Identical tapped pipe (TP), tapped horn (TH), but notice the TP must be longer by exactly its Fhm offset for a given Fb.
Yeah, I was an impressionable 10 when I helped my then neighbor build his to supplement his Karlson K15 kit co-ax 'FR' speaker I also helped with. The cab ultimately was turned into a storage bin and the cardboard boxed Jensen wide range LS woofer (OEM PLL was way too expensive for any family in our neighborhood) has been collecting dust in various basements, closets since '60. In a quick 'peek', the one piece cone doesn't appear to have any stress cracks, but would have to be carefully moisturized like a rare book to even think about applying any power to it, though doubt there's anything can be done with the spider, but at a base efficiency of ~102 dB/70 Hz in a 12 ft^3 cab, not much need for one. 😉
Isn't this a tapped Horn.... How does Tom D get all the credit?
Yes, a straight flare TH = ease of build.
TD's a positive flare TH = big and loud.
T-TQWT or T-TQWP is a negative flare TH = small and low.
Hofmann's Iron Law
Three parameters that cannot all be had at the same time. They are low-bass reproduction, small (enclosure) size, and high (output) sensitivity." Hofmann stated that designers could pick two of these three parameters, but in doing so, it would compromise the third parameter.
Reactions: camplo
more potent resonance/cancelation freqs if ‘driven’ at both ends in phase or out (or 90 degrees in between @ resonances?) of phase with the 1/4 wave shapes /motions?
Reactions: camplo
Yeah, me n' Freddyi gave Tom a bit of a hard time initially re this and some others Freddyi was aware of, but IIRC Tom claimed no knowledge of them, though his design was sufficiently more advanced to be a much more technically correct 'TH' and no one to legally contest it, so DSL rules! 😉
My neighbor's that I helped build in '56 to complement his K15 DIY kit was an unbelievable experience in a time when typical bass was 80 Hz.
Reactions: Booger weldz
Tom Danleys has a very limited bandwidth before you run into the chaos of a bunch of 1/4 wave freqs that cancel and resonate. That all sounds bizarre and especially if coming out of a big mouth/exit?
the tapered or stepped reduction versions (long skinny bass reflex?) seem to be the perfect compromise for home/car audio maybe ?
i guess it’s the best way to get a big potent subwoofer that’s not plagued with all the pipe noises and issues. but it’s also not a screaming little reflex port/tube underdamped peak or chuffing ?
you get the cone control of the long skinny ‘chamber’, but the actual ‘port‘ size is bigger ?
(if that makes sense? 😝)
Yeah, if there was an arguement, how could these things not ‘win’ ? I can’t find anything ‘better’ for the ‘ultimate vented subwoofer’. But most definitely ran Into some weird stuff trying to .
If I use 2 Sd folded into 1/2 Sd there’s never pipe resonances/cancelations in the way. nor is there a port velocity issue ?
the pic on the bottom is no different in box volume (assume all the drivers are mounted right at the vent exit). And the tapered version at the top doesnt tune as low?
If my memory serves me correct, A proper flair is only other way
I think I meant to delete this part of the post but my thought was;
Tapped Horn
Offset TL
Proper Flair at the terminus/mouth
TaperedTL/MLTL/BR
Any other vented solution has harmonic issues in the FR?
Tapped Horn has limited BW towards the midrange
Offset TL has crazy GD
Proper Flair for Bass is Gigantic?
TaperedTL/MLTL/BR.... Whats to hate?
I wonder how does offset Tapped fair
Maybe Use Offset tapped pipe if you don’t reduce the crossectional area and the pipe is so long that second resonance and cancelation are at 3 and 4 x Fb?
