DIY ACA mini
Good idea to include gate stopper resistor options, even though they don't appear on the original ACA Mini.
Is the footprint for the H2 switch contacts, compatible with some sort of PCB-only jumper block? If someone builds two of these amp channels in the same chassis, it's possible they may not want to enable/disable H2 using a double pole switch, which likely requires two pairs of signal flywires (one wire-pair per channel) to that switch.
What would the proper values be for gate stoppers? Thanks.
You'll need a CRO (oscilloscope) for this exercise to really see the effect if any. Mr. Pass had his reasons not to include them and I guess they are good reasons.
I personally like gate/grid stoppers with mosfet/tube devices.
Start with 47 ohm and go up if necessary. I doubt if you'd need more than 220.
Reactions: audiosteve
Reactions: lastnamenelson
Thank you Nelson and all for sharing so generously, I have ordered a complete kit and am reading thru the posts. One thing that piqued my interest is the Mini Tower that 1 poster did with the ACA mini & ACP+. I was thinking it would be very cool to be able to make something like this w/ 2 inputs, what a cool integrated that would be?
I should add when I said "it would be cool to make..." I wasn't referring to me as I am a complete novice.
If you want to make a combination of ACP+ and ACAmini, the logical place to start would be building both as normal, getting them adjusted and working properly (easy and straightforward) listening to them and falling totally in love with the sound (also easy) and then figuring out how to combine them in a form factor you find interesting. It’s DIY! Jump in, the water is fine.
Just finished the ACA mini and need some help/suggestions. When I hook it up to my system I get nothing but dead silence. I measured the values of every resistor, double checked capacitor orientation and orientations of all transistors. Discovered and reoriented a one backward Q1 and one Q2. It adjusted properly: VO= 11.508 or so volts in each channel; VB adjusted to .303 volts in each channel. Pictures below. What should my next diagnostic steps be?
Thanks 6L6 for your reply. That was my suspicion as well-- something up stream from the ACA mini. I'm using a DAC as input from another system that works . The cables, etc. all from a known good system. This doesn't mean that I haven't done something wrong somewhere but I think I've tried the usual suspects. Maybe re-do it all again???
Mystery solved. I had two different DACs that both worked in other systems. Neither worked with the ACA mini. Tried a few more things and discovered that both my phone and tablet (tried both of them, too) had the volume turned all the way down. They feed a digital signal to the DAC. Turned it up and the ACA mini works like a charm. I'm playing it through horn based speakers and to me they sound noticeably honky compared to my previous amp. Would adjusting VO/VB make a difference on this front? I removed the jumpers and I think that may have helped but I'd have to A/B them some more to be sure.
Thanks you for your kind responses.
