Pioneer SA-9500 hum problem
As illustration - noise caused by two transistors Q1 and Q3 (compare this to the traces in earlier posts):
use the same Idss ranking that's on the original, you can compare the two specs to be sure.
in the old days 🙂 they used paint to identify Idss and hfe ranking, that's where the suffixes that they use today come from, unique to Toshiba,
BLue,Yellow,GReen etc.
2sk30 is in the old package, it goes way back.
I have read on a few occations 2sk30 were changed to solve a noise issue but usually they change 2sk30 and 2sa725 together so not 100% sure its the 2sk30 by itself. change the 2sa725 first, if that does not do it, change the jfet. good luck.
Reactions: madis64 and Netlist
