Inverted mounted driver polar-response
Thanks, dcgold, this is quite interesting.
(1) If I’m interpreting your chart correctly, in a downward firing position, that driver emits a roughly flat response from the back, over 360 degrees up to about 10KHz. Is that correct?
(2) Is the variance in response amplitude from the back about the same as from the front when the driver is conventionally positioned, or is it worse?
(3) Can I safely presume that the 10KHz response knee mirrors another 10KHz knee from the front axis of the driver when it’s conventionally positioned? In other words, is it simply due to the high freq. roll-off seen from the front axis of the driver?
I'd rather see a polar plot, from 0° on axis (directly above) to 90° off axis (horizontal), as it is going to be used in a presumably sealed enclosure.
Yes, a polar plot would be best, but, as dcgold alludes, that is much mored involved to produce. His offer to plot the response at a few horizontal angles around the cone should still prove quite informative.
Why, the presumption that it’s going to be used in a sealed box?
Reactions: ripblade
Okay, I see. Because my primary area of interest is in the polar response above the ka = 1 region, I had wondered whether I may have been missing how the driver loading could somehow effect the response in that region, in the inverted omni configuration.
I hope the graph names are descriptive enough. The front firing are obvious, the "firing outward is the driver facing up, out of the cabinet. The front I measured on axis, 20 and 35 degrees off axis. The remaining are on axis - directly behind the driver, 30, 45, 60 and 90 degrees off axis. Feel free to toss me questions, I'll do my best to get back quickly. All measurements are in an approximately 0.5 cu foot semi-dipole – damped open back cabinet.
dcgold, thank you, for producing the many above plots which, essentially, appear to indicate significant high-frequency response does exist horizontally (at 90 degrees off-axis) around the back-side of an inverted-mounted driver. Interesting.
First SB12PAC
Then SB65WBAC25
I would caution against using the rear of the driver as the main radiator. When I've measured it the rear response is not as clean as the front response, there is significantly higher distortion.
Here is front vs back of the SB12PAC.
Then ND105.
Just looking at the pictures of a BAYZ Audio speaker…it appears to use to inverted larger SB Satori drivers with the 6.5 inch drivers frame and magnetic assembly used on the back. The crossover is reported to be 2k. I image a lot of the character of this design is the pulsating(?) tweeter and equalization if any.
Reactions: jmpsmash
That’s true, as your plots, and CharlieLaub’s plot in comment #2, indicate.
The reason we were exploring the response at the rear of drivers was in an attempt verify, or falsify, the presumption of Ohm Acoustics, and of many onmi diy builders that a normal woofer mounted-vertically and inverted, will, indeed, radiate horizontally 360 degrees across the full bandwidth of the driver. In other words, as a Walsh driver does.
Sorry to sy, but IMO OhmWalsh description of how they work is makebelieve bulls#t . Seems like they have no idea or measurements of how soundwaves of different wavelength radiate. The rearside of a cone driver has spider and motor too making major interferences, adding distortion by that way.
A more sane approach comes from Bang&Olufsen. Even there each radiator has quite narrow band of clean operation.
https://www.bang-olufsen.com/en/int/speakers/beosound-2-ferrari-edition
https://www.beoworld.org/prod_details.asp?pid=800
Juhazi, that is my feeling as well.
In that Ohm patent, they specify crossing over the inverted woofer to a super-tweeter @ 8KHz. While the plots made by the contributors in our thread do appear to indicate significant radial output at that frequency, as you correctly allude, that output is very jagged in response. Indicating reflections, cavity resonances and diffraction effects from the basket, spider and motor.
The relevant Ohm Acoustics’ patent: https://patents.google.com/patent/US4440259A/en
To be clear, a Walsh driver is different, and covered under a different patent: https://patents.google.com/patent/US3424873A/en
Just looking at the pictures of a BAYZ Audio... The crossover is reported to be 2k. I image a lot of the character of this design is the pulsating(?) tweeter and equalization if any.
FYI - Regarding the proprietary Bayz Audio psuedo-planar tweeter. It resembles a multi-sided, so-called, ‘Rubanoid’ tweeter.
Here’s the BAYZ tweeter patent: https://patents.google.com/patent/US9088849B2/en
If anyone has been curious, here are front and rear photos of the inverted woofer mounting - with a dome tweeter perched on top of the magnet - used in Ohm’s affordable non-Walsh driver speakers. It definitely appears to be a typical, inexpensive cone woofer, and not a costly Walsh driver.
