And yes, the screwdriver will be removed![]()
why, it's so sexy looking ......
Have them in hand, should have asked this first but, having the same case, do they, like the mosfet pucks not need insulation, only paste?A close look at the pictures in the 6 Moons review shows the large SOT-227B “hockey puck” style components. The part numbers are not visible.
I have used IXYS VBE60-06A rectifiers with good results in some of my recent builds. They are relatively quiet and have low voltage loss in higher power/voltage applications.
Also, will the perforated inner floor of the Deluxe 5U case sufficient for heat sink purposes, or do they need to be on a heat sink?
Thanks,
Russellc
Just "simply" balanced.Mono blocks. So this is balanced or bridged?
Very interesting 🤔.
Russellc
Russell, looking at the picture, unless I am missing something, I believe he is just saying that it is a XLR (Balanced) input. So you do not necessarily need a balanced preamp. The amp itself is not balanced. It would need two more output devices to make the quadrants needed to be a truly balanced design.
Although a balanced pre would be fun.
The BA3B is pretty interesting. Consider the 313/2013's if you are going that route. They sound nice. There is the F5X which I believe has been implemented as a headphone or preamp as well. That one looks nice. Then there is the Iron Pre, the pumkin, the turtle etc... So many neat options.
Mike,
looking at the input stage I think (and ZM says too) it has a real balanced input, and can also be used as SE, when neg. input is grounded. But ZM will surely correct us.
speaking of any diode bridge- Modu base plate is good enough (even if steel, due to enough area), just use thermal paste and don't forget split washer under nut
IXYS bridges are (normally) having base plate insulated from diodes, so no isolator sheet needed
funny scenario - even intentionally - how could designer decide which of 4 diodes to connect electrically with bottom of case ?
I have those and the rest of the parts boxed away in the bba3 box!Russell, looking at the picture, unless I am missing something, I believe he is just saying that it is a XLR (Balanced) input. So you do not necessarily need a balanced preamp. The amp itself is not balanced. It would need two more output devices to make the quadrants needed to be a truly balanced design.
Russellc
Oh. I saw one board in each mono block, heatsink on each side. Repeat for the other mono block so figured each mono was balanced like with the bba3 mono blocks.Russell, looking at the picture, unless I am missing something, I believe he is just saying that it is a XLR (Balanced) input. So you do not necessarily need a balanced preamp. The amp itself is not balanced. It would need two more output devices to make the quadrants needed to be a truly balanced design.
Figured if it's going to be balanced, may as well do the pre too!
Russellc
For the front stage to be balanced, wouldn't it have to put out a +phase and -phase into the output stage? It looks like one trace going from the output of Q1 and Q2 into the output stage. Maybe I am wrong too and Zen Mods tricks go right over my head. lolMike,
thingie (Babelfish XA252) is having bal input FE and regular simple Push-Pull OS
when speaking of OS itself, things are usually clearer if we use "bridged" instead of "balanced", as term
If I don't ask where I don't know, I'm liable to release the smoke! Of course there is learning from smoke. I figured it would be sufficient speaking of inner floor of case, just remember my first FirstWatt clone build F5. I used individual rectifiers four on each, all 16. Installed them all, then discovered that each piece needed to have insulation pad.speaking of any diode bridge- Modu base plate is good enough (even if steel, due to enough area), just use thermal paste and don't forget split washer under nut
funny scenario - even intentionally - how could designer decide which of 4 diodes to connect electrically with bottom of case ?![]()
Russellc
Well, I am confused about two channels in each mono block then. Not for now anyway, I haven't got the "regular" version running yet!@Russellc very nice 🙂. those should serve you well. The negative binding post connects to ground which means it is not a balanced output.
The balanced circuits are interesting to learn about. The BBA3 is a good one. Your BBA3 box deserves to be opened 🙂
Russellc
It's confusing to me b/c people often use balanced / differential / bridged interchangeably, and they are not.
Are you referring to post #1260? If so, where do you see two channels per chassis? Monoblocks are mentioned, but I don't see mention of two channels per chassis.
1260, first sentence. Answer "balanced" in 1264
Maybe I misread or mis understood? Quite possible!
Russellc
Russellc
Well, I think my brain is transposing BBA3 info, with xa 252 info. With BBA3, each board is 2 channels, not case with xa 252...so mono blocks, you are correct.It's confusing to me b/c people often use balanced / differential / bridged interchangeably, and they are not.
- Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
