Full Range Speaker Photo Gallery
The 11maops landed today, so (after a running-in period) I'll be able to offer a view as to whether (1) they are physically identical to the 11MS, (2) if I can tell any difference, (3) if there's improvement (in my opinion) and (4) how happy I might be about the additional £340 [$550 Canadian] I just threw at this project.
They're in... well, almost...
(1) The maop unit is a smidge bigger than the alpair11ms, so some gentle 'rasping' will be required for a snug fit (its about 1mm or so)
(2) I can tell a distinct difference already, honest! I left them running for 40-ish hours with looped Keith Jarret in Koln. The soundstage is no wider, but (I'm certain) they are much more crisp, immediate, confident; the sound has a sense of presence & proportion - so much so that:
(3) I'm satisfied there's a big improvement - especially with some of my favourites. For example, I feel like I'm sitting in the studio with Ella Fitzgerald & Joe Pass, as opposed to listening to them (esp. A Foggy Day, from take Love Easy, 1973)
(4) I might be deluded, I might be suffering from "new stuff" syndrome, but today I'm very happy. 😍
There's time yet...
If anything changes... I promise to let y'all know👍
My Super Pensils. Pride and joy.
My current folded open baffles, used between two systems and a sub.
Trying out (yet again) a rear firing tweeters, but I think it's not staying.
In phase with the front, it ruins imaging. In phase with the rear, it's inaudible.
A wider sweet spot than with my 12 inch whizzer cones, and after fussing with a few styrofoam panels and configurations, no eq required for these.
My best home theatre system speakers, and my best sub sat speakers.
How about a rare UK speaker from 1999. Pentacone Pentowther.
Unfortunately I have no information on the company.
It has a set of Lowther PM6a drive units installed and they sound fantastic.View attachment 1208472
Tall and angular. Ever take it apart for a peek inside? I had a pair of D700 Tannoys year ago, in which the DC cone on one had a factory defect which caused it to split apart vertically. I removed the unit for warrantee service. What was advertised as a ported speaker had a dividing wall which supported tge driver motor/magnet. It looked very much like a transmission line, adding signal path and reflections to the cabinet end in front, from one end to the exit would make for a line about 13 or 14 feet.
Maybe explains how it seemed to be flat and rock solid to 30hz without much excursion.
i figured the nicer they look the less i would worry about them not being a two way and wouldnt have to include the dark art of crossovers!!
ive got a little cnc router tucked away in the garage so that was a 6mm ball end mill pecking at different depths.
i machined the cut out for the driver and the vent and included a little round over using a 0.25mm tapered bit, took forever...
Reactions: MITsound
Build of the Woden Baby Labs Bloodhound with CHN-50. Made from 12mm multiply birch. Applied water based stain in mahagoni bright. 1 Layer of hard wax oil. Still burning in, but already impressive what this small speaker can do.
I have not yet decided what to do with the cable terminal. Its to deep to fit in the back panel. My idea is to build a sort of back pack to compensate the depth or just leave the cables as is 🙂 .
8cm JVC fullrange driver, both sides covered with thin aluminum foil from the gold Smith (sandwich structure) and copper Faraday ring in plastic box from TV production.
See:
https://www.diyaudio.com/community/...loudspeaker-sandwich-cone.402917/post-7443470
Subwoofer reflex loaded, 8cm reflex diameter, damped 30% with baf wadding and low tuned in a marble box. It's Galala marble.
20cm no name driver (Skytronic) with polypropylene cone. I added a big paper dust cap for more stability. It's for watching TV.
One ohm in line with the fullrange driver (Esa Merilainens simple resistor method, see website current drive info) I took it out again. Distortion gets too low. It sounds nicer with a little bit of distortion.
Reactions: ziffel
Since you only need a single pair of terminals for this driver, a shallower recessed cup or even surface mount binding posts could suffice quite nicely.
With a single 1/2” layer of scrap material as a spacer the smaller cup wouldn’t intrude into the space of the final fold significantly, and the surface mount plate would only require a pair of holes for the wires (1/4”, or 6mm, I think)
I used literally hundreds of a cheap 2” recessed cup over the years, and could never get anyone to demonstrate the sonic advantage of the heavy mass, gold plated audiophile jewellery types - the advantages of lack of formal ear training and low standards, I guess 😉
I used scrap pieces I had lying around to fabric the backpacks. They are about 30mm deep. The cap alone is something a little over 20mm. I think (I hope 🙂 ) I have not destoreyed the bookshelf capability since they cant be placed against a wall anyway because of the port.
I drilled a hole 25mm in diameter to pull the cable through.
Reactions: decramer
