Full Range EQ
Just finished soldering the board but when I tested it out the EQ is not working. Can’t figure out why it’s not working and don’t know how to trouble shoot it. Any suggestions?
After replacing the resistors with correct values I have the Full Range EQ working now, it sounds really awesome, I’m getting a bit of buzz in the background that the EQ seems to to introducing ie it’s no longer there when I remove it. Any suggestions as to what it could be?
I’ve populated the board according to the example in the Nelson Pass article. Im using a Meanwell power supply and running it between my laptop and an Amp camp amp mini amplifier, speakers are fostex full range speakers.
Reactions: Fox
