1000W Simple PA Amplifier
can replace potentiometer 5k with 10k?
Hi Apexaudio why did you choose 2SC5200 + 2SA1943 transistors?
Automobile relays are not suitable for switching high voltages of 110V, their contacts are too close, the arc may not break between the contacts from the amplifier output to the speakers.
+HV=+high voltage, the + of power supply.
As it isn't a current sensor in this amplifier you must add a small circuit for bias (voltage on emitter resistors) for overcurrent detection.Output of this circuit will be the Pro.connection
You can find this add on circuit somewhere in the thread.
