Acoustic Horn Design – The Easy Way (Ath4)
Still struggling at that point here...
Any ideas?
I'm quite interested in modding the file for a 1.5" throat and testing on my Vitavox S2s. Depending on cost of having them printed locally..
In theory the S2s can do 500 or 600Hz up and some use them like this - with a nasty bump at 1000Hz or so.
Be fun to try..
I'll have to have a listen to my mid bass horns playing higher first though.. 400Hz yes probably, 5 or 600 not so sure..
I hadn't much of a clue what to expect but certainly not that there will be virtually no obvious resonances caused by that long throat extension.
(The joints at both ends of the adapter are not even very smooth at this point.)
- It also solves the biggest problem, which is the aesthetics of short horns. This looks much better. 🙂
Reactions: aragorus
re' reflections: show me the discontinuity then
you put all that effort into eliminating discontinuitys plus into the mouth termination, you shouldn't be surprised when you see very little that looks like a reflection or a standing wave/resonance resulting from a strong reflection
