SB Acoustics SB20FRPC30-8 (8" Fullrange Cheap Monster II)
Lowther drivers with large phase plugs.
Yeah, gearshift knobs, various organic shaped bottle caps, etc., have worked well IME, though needed the female's inputs to choose since I tended to only notice any obvious off axis differences. Personally preferred putting 5 star shaped stick-ons to the dustcap and knead the whizzer to work out its excessive starch to 'taste'.
Reactions: LeifB60
I tried measuring the on-axis response of the SB Acoustics SB20FRPC30-8 driver with a ping pong ball attached to the phase plug.
There is a slight change above 5kHz.
In terms of perceived sound, the presence of the ping pong ball results in smoother high frequencies.
It's intriguing how the addition of just one ping pong ball can alter the perceived sound.
I look at the freq response charts. the one with ping pong looks more jagged than driver without ping pong in areas above the 10 K hz frequency .
How does it correlate with audition ?
Reactions: nandappe
The change above 10 kHz is worse on the graph, but audibly it's a high quality sound with little stimulation.
It's purely my speculation, but it's possible that the off-axis characteristics have improved.
I tried these in a 2-way with Peerless DX25BG60-04 (crossed ~1.8k). But also added a switch to cut the wideband over to another set of terminals with baffle step and a notch to pad down the upper midrange a bit. Allows me to try both 2-way and FR. The 2-way can handle more technical stuff, but the 8" by itself makes more simple music quite spooky (in a good way). In fact I enjoy how it can take a track that is a bit too harsh (IE a "hot" mic that picks up alot of sibilance) and make it more listenable without losing perceived detail.
In-room response of the 8" by itself with the BSC and notch (~3k-6k). The notch only drops a few DB to leave enough on the table off-axis to play with toe-in. Easy enough to alter anyway by swapping out a resistor on the notch.
Enclosure is ~32liter. A design I came up with to use a single 2ftx4ft sheet per enclosure. Rear ported with a set of 2" precision port flares butted up to make about 4" estimated length. Nothing special about the bass, not amazing, but not bad. I find it adequate to provide an anchor to the music for the midrange to shine.
post #516
How about Grounding the driver frame?
see the end of Tony Gee Solovox 206 pdf
https://www.diyaudio.com/community/attachments/solo-206_copy-pdf.1185555/
That’s not really grounding the frame, that’s connecting the negative wire to the frame. I might be splitting hairs here. (But isn’t that what we do?) I’m not sure that will do anything except open up your system to electronic/electrical noise. Running the vacuum might send a lot of energy into your amp.
I think it may be acting like a resistor or capacitor and cutting some bass and adding more treble. I’d like to see some measurements. Easy enough to put a switch on it.
