XSD Speaker Flatpack GB
Hi Folks,
I have good news. We can do the XSD flatpacks for $600 a pair. This is with 3/4in birch faced Tru-Ply and 3/4in MDF on the woofer array box as shown above. The flatpack will be packed in foam, cardboard corner protectors, and a large box with straps so will arrive in great shape.
Shipping only in USA. Typical cost from Texas to Virginia was about $115 via UPS.
Sign me up!
Russellc
Thanks for the effort! Very much appreciated, great price too. This makes the difference in getting this build to completion. Haven't built speakers since the Econowave craze. (Which are still in my living room, thanks Zilch, RIP)
Russellc
Gluing the baffle and base now.
Is there anymore interest in a GB for this flatpack? Birch faced poplar plywood. Cosmetically perfect birch veneer. $600 a set precision CNC cut and nicely packed for secure shipment.
Reactions: Russellc
Yes please. I will never get this done otherwise! I am ready to build. I will buy one even if no one else signs on. I know I'm not the only one! Getting closer!
Looks like I will need to invest in hand weight. Quite a collection there.
Russellc
I will get one with or without dowels. Most "box" speakers require just as much if not more clamping. This one really isn't bad at all. Bass part is only trick. The dowels should simplify this part. I will be happy to do a beta buy!!!
Russellc
Reactions: xrk971
Those 30mm dowels would be fine for baffle to woofer and base to woofer alignment.
But wouldn't three 7.5" long dowels through the 5 panels at the top, middle and bottom of bass assembly be better than multiple short pieces?
I was thinking the same thing originally. But then thought that the longer pieces might be tricky to push through if a tight interference fit for better alignment. The short ones are fluted and meant to tapped in with a hammer. They might actually provide a stiffer and straighter alignment than a long one with clearance.
I am no wood worker so happy to take suggestions from experienced woodworkers who have done something similar.
Reactions: Russellc
I have made the request for the CAD model to include holes for standard M6 x 30mm long fluted wooden dowel pins.
3 for the woofer box stack (thru hole for all 5 sheets)
6 for the baffle to woofer box (blind)
4 for the base to woofer box (blind)
These are the typical dowels we can use:
https://a.co/d/j8xXpAg
Its an Ikea idea!
