Salas DCG3 preamp (line & headphone)
I'm laying out DCG3, FSP and 2x6-24 crossovers in one 2U chassis. All Transformers and PSU's in a second 2U chassis
I'm having space issues with 6 x50va transformers and psu's in one 2U
Any issues if I used 2x30va Antek for DCG3 and 2x30va Antek for FSP. - This would work out and be a nicely filled chassis.
If necessary, I would step up to a 3U but my preference is to stick with the 2U
Thanks!
*There are the R1 R2 33R setting current for J1 J2 which finally runs through the LEDs. Check mV drop between each 33R resistor's own legs to see if about the same. Just to confirm no J was also gone when your original mishap crippled those two LED bars.
Now that I remember it, I thought I was missing the 33R resistors, but later saw that teabag had included 1R in their place in my kit, so I used them. Does that make sense? That way at least one channel is about 5mA, the other one a little lower. The above numbers are with 1R values in R1, R2 in both channels.
A 3 day old DCG3. Hard to imagine a better preamp is available anywhere on the planet!🙂
I'm laying out the combo boxes as well for a few 3way active systems
The plan is for 2 sets with 3way xover, phono and DCG3
Also one more set later with Xover, dac and dcg3.
50 va trafos are little large so 4 will be 30va. Also want to add a Soft Start board..
And the DCG3 on post 6916 I plan to build a 2 way xover in a 1u galaxy matching the width
I'll need a few more dcg3's from the next groupbuy
