The Kef B200 was in loads of speakers around the 1980s, and there still seems to be a few about.
Rubber surround so no foam to rot.
So the question is "how good is it"? Is it worth using for a 2-way speaker project, either sealed or ported?
Is it still competitive or are there better 8" drivers available these days?
The SP1014 is the common one with the smaller magnet. Are the larger magnets any better, like SP1039?
And I gather the crossover needs to be 3K or below, but I haven't seen any frequency responses for the B200.
So - worth using or pass?
Andy, I can't answer your question, but I recently bought a pair of Kef 103.2's and in reading about them, found that the rubber can go stiff. Mine are fine though. These have the SP1075 version.
Can you treat older rubber surrounds with any kind of stuff that restores their flexibility?
Could well be an issue with 1980s drivers. Over 40 years ago - long time!
The different models of B200 simply catered for different types of enclosure loading.
The small magnet SP1014 was used in the compact infinite baffle KEF Chorale speakers, while the large magnet SP1039 was used in the larger ABR loaded KEF 104 and 104aB models.
As B200 replacements, Wilmslow Audio recommend the Monacor SPH-210, while Willys Hifi recommend the Monacor SPM-205.
However, their Thiele/Small parameters are quite different, meaning they must be chosen acording to their intended application.
Yes - I saw those references you mention. My question is whether it's worth getting the B200 itself or a more recent 8".
How good and how competitive is the original B200?
I'm sure, depending on application, that there are better 8" drivers available today.
There's what looks like a nice pair of SP1014 drivers available at a "buy it now" price of £70 right now which may not be too much of a financial risk.
My personal preference if designing a speaker system from scratch would be to employ brand new, modern drivers in order to avoid potential problems.
It is a 50 year old standard range driver and old ones will likely have deteriorated needing attention to bring back into spec and refurbished ones could be in any state. All decent modern standard range drivers from the likes of SB Acoustics, SEAS, Scan-Speak will offer better technical performance but the set of driver parameters is likely to be a bit different. Speakers have evolved with higher power, better tweeters,... which has altered what is wanted from a typical 8" these days compared to 50 years ago.
If you are looking for the performance of a modern speaker design then an old B200 is almost certainly not a good choice. If you want a modest priced retro design then there are not many suitable modern drivers around (but there are some) and an old B200 for £10 or so may well be a reasonable contender.
There's a lot of nostalgia for Kef drivers of that era - the T27, B110 and B200. The iconic LS3/5A has probably kept alive a bunch of drivers that should have been part of audio history. I'm just checking whether these old drivers were mythology or whether they are still worth incorporating into a new build. I never had a speaker that had a B200 so no personal experience.
Do you already own some? I'm a believer in working whats at hand into my projects. A minority view, I appreciate. If you work the design around the driver, you'll come up with something good. If you are intending to buy, you might get something new for the same price thats better and easier to design around. I love the old Seas 25f-ew. But thats because I picked up 4x for next to nothing on a whim!
Technical performance isn't everything and retro/nostalgia can have significant value for some. For example, I have a budget retro 10" + large tweeter near the top of my todo list. It won't offer high technical performance for the money but what is of value to me is the fun trying to get it working well in the manner of a fair few speakers from my youth.
Where the value of retro can go a bit wonky is when retro enthusiasts reject reality and claim the object of their desire has a high technical performance. The LS3/5A is a striking example of this but here in the UK it applies to a fair few old designs. What they all seem to have in common is that they were all originally adopted as high value "subjective" audiophile designs despite their modest technical performance. Whereas engineering value inevitably reduces with time due to technical progress and physical deterioration this marketing value can be preserved or even grow for those that place value on it.
I had the Audiotronic CM-3 with two KEF B200 in a Baily TLS fo about 15 years. Sure they got stiff over time but silicone oil used for rubber boots will soften the drivers. I have used them in closed boxed and vented as well. I think modern polypropylene drivers (Seas and Peerless) sounds better than bextrene drivers like the B200. I replaced the 2xB200 with a a KEF B139 and a Audax midrange and that combo was far better.
The B110 and the LS3/5A is overrated, back in the days I thought that the KEF 101 sounded better than the LS3/5A (both using KEF B110) and that the contemporary B&W DM5 sounded better still. But the LS3/5A is a legend and the DM5 is forgotten so what do I know🙄
I have 16 KEF B200.
I am still trying to reconcil the small sealed boxes (the CHorale mentioned and the Tangent TM3 for instance) with what modeling suggests.
Can’t get at muymodeling computer but found this TL from Scott.
dave
dave
The low mid/bass emphasis around 100Hz of the LS3/5a, was a deliberate design choice in order to provide low freq illusion especially when near-field. The KEF 101 was flat (in fact a very gentle roll-off started from ~180Hz), so they are different animals, each one excelling in different conditions.. . .
As for LS3/5a VS DM5, you have a 4,5" VS a 6", so it's not an apples for apples comparison.
May I ask what you consider these two speakers excel at in comparison with modern equivalents (e.g. Neumann KH 120 for the LS3/5A and, perhaps, LS50 for the 101 but arguable). Not trying to have a dig but to bring out a point about retro enthusiasm.
Retro Rules! 😀
I prefer to listen to my 60s/70s LP collection on speakers that are contemporary.
But do carry on with what could be a lengthy discussion!
I secretly fancy a pair of Kef 103.2s. 🙂I prefer to listen to my 60s/70s LP collection on speakers that are contemporary.
jeff
There is some stuff used to refresh the rubber rollers in copiers and printers that might work.Can you treat older rubber surrounds with any kind of stuff that restores their flexibility?
Rubber Renue
My comment followed the comparisons in DrBoar's post #13, and was not reffering to LS3/5As VS "modern equivalents".May I ask what you consider these two speakers excel at in comparison with modern equivalents (e.g. Neumann KH 120 for the LS3/5A and, perhaps, LS50 for the 101 but arguable). Not trying to have a dig but to bring out a point about retro enthusiasm.
Regarding those you mention, I have no opinion as I never auditioned the Neumanns, and the LS5's only under very-very bad conditions .
Just looking at the specs and what is oferred under the retail price, I speculate the KH-120 would be a better (maybe by far) buy as a whole than the LS3/5a. I do have some doubts though concerning it's ability to match the LS3/5a regarding the "flow" of the music and when reproducing human voice.
- How good was the KEF B200?
