VRDN: bipolar regulator PCB for line level ckts: ±11V to ±20V @ 1.5A with "De-Noiser"
Yes, my investigations suggest the differences in the various LM317s are minimal. The suffixes indicate things like the type of package. See
https://www.onsemi.com/products/power-management/linear-regulators-ldo/lm317
for the comparison between the different models. They all have suffixes. The LM317TG seems to be the basic one in the TO220 package. The B adds something, but I can't see what (other than a few cents).
I see that as well now super minimal. So maybe the real question is for the "parts list", Mark can you say was the selection of LM337TG just chance over the LM337BTG. And same with the LM317BTG was added to the parts list by chance over the LM317TG. Or were they selected for a reason.
OK getting closer. I think power one of these up today. Yes, I’m still missing LM 317 and 337 on the one board. I’m expecting them tomorrow.
Reactions: Monk55
A bit of help please on one of my VRDN regulators, the negative voltage rail is not adjustable. It’s giving me -23 VDC. Do you think the trim pot has shorted out? or the LM337 is faulty in someway. This beyond the scope of my paint by colors and not sure even how to check either one or test them. I have the parts to throw at it and see if it fixes it. But would rather learn something! If someone has the patience for that task. 😄
Yes, the first one both left and right sides positive or negative fully adjustable to +18-18 Vdc.
The second one just the positive side is adjustable to +18 V and the negative side is nonadjustable at all. Just sits at -23 Vdc. And no heat or magic white smoke 💨
OK I decided to go ahead and to replace the LM337. Well that was hard to get out. Put the new one in still have the same problem. This is well above my pay grade. Any ideas?
Did you build it with a different LM337 than specified but use the normal parts from the Rev.A BOM? If so, you'll want to read Mark's info in post #198. It refers to TI parts but can apply to other versions of the 33x chips, if I am not mistaken.
https://www.diyaudio.com/community/...o-20v-1-5a-with-de-noiser.355883/post-6451732
Additionally, you'll want to see Mark's other info on post #694 (which links to other posts):
https://www.diyaudio.com/community/...o-20v-1-5a-with-de-noiser.355883/post-7322633
