Baltic Birch and rubber baffle
This thread gave me an idea! I'm already planning to front mount pro-audio drivers, with a polished aluminum ring to hide the flange and gasket....and securing the driver to the cabinet by bolting through ring, "sandwiching" the driver.
It would be easy for me to add a viscous rubber material to both sides of the driver's flange. (Probably remove the stock gasket.) Then the driver should be completely de-coupled from the cabinet?
It should be easy to do, and it shouldn't require any modifications to my design. So thanks guys! I don't know if it makes any difference practically, but doing it would take so little extra effort that I don't have an excuse not to!
Has anybody thought about a 2mm layer of lead in between two sheets of birch ply? The plyboard isn’t very dense so this may be a way of adding mass to the baffle. Anybody tried it?
Any material would work is used the right Way. But if you use 21 mm Birch play and 2 mm lead, I bet that is waste.
However, from my experience, glueing two sheets of material together makes for at better panel. Ie: 2x9 mm Birch glued together is better than 18 mm Birch ply.
I would strongly advise against the use of lead. There is a good reason it is banned in many circumstances.
I suppose the lead would lower and even amplify the resonances. As far as i know the reason to use (strong) plywood in the first place is to get a light but stiff material to push resonances above enclosure/driver bandwidth.
Edit: the above is probably most valid for bass enclosures. Mid enclosures may be different, as the panel resonances are below useful bandwith. In this case lowering resonance frequencies and adding weigth may be useful.
I don't believe that more mass = better. There are lighter weight methods for making non-resonant panels. For example, tensioning the cabinet, or constrained mass damping.
I've been dreaming about endgrain balsa core composite panels, so endgrain balsa in the middle of the panel, with thin plywood on either side. And then carbon fiber on both sides. I really want to do it, but I estimate it would be approx $600 in material to build, before the carbon fiber! I did some tests that indicate it should perform roughly the same or better than plywood. But I decided to just go ahead with MDF, since that is cheaper and simplifies construction. I mean, I kind of want to finish the speakers!
Before going full out on such a project, it would be interesting to take apart an existing speaker and replacing the baffle with the one suggested and measuring the effects. Unfortunately I don't have a set of speakers lying around waiting to be hacked.
(notwithstanding the three ~stalled projects I have in my garage because somehow I have less time now than when I was going to work every day ???)
If you are measuring differences and considering using a different configuration/geometry, wouldn't knocking together a simple sealed box suffice?
Given that the amount of energy to excite a (potential) resonance decreases quite dramatically with frequency. So the technique has been shown to work with single FR speakers. I would not do a mid enclosure any different.
dave
Reactions: stv
Lining a cabinet with cork might help absorb internal sound and stop it being transfered through the walls.
On my latest project, I glued felt to the inside, then glued carpet tile to the felt, in an attempt to do the same - and to see if it would dampen the MDF sides. To be honest, after knocking on the sides it doesn't seem to have made a lick of difference in regard to damping, but it's restricted to a small area due to bracing.
I'm curious and interested in this speaker's unique cabinet build:
9mm ply + 4mm corkboard + 9mm ply constrained mass damping.
I wonder how effective it is?
Would it make a competent speaker? I think yes. Is it "the best" combination of materials? Hard to tell.
I wanted to try the concept, but I decided against doing it because diminishing returns. It costs more and introduces a lot of complexity.
Yeah it is complicated. And gets expensive with linoleum. But who dont want antistatic properties ;-)
I found that PVA Glue bonded just fine to cork - in perfect World I would have used a Glue that is a bit softer.
I have seen vintage drivers that have a gasket made of cork. At least 50 years Old. It looked brand spanking new.
Anyway i May shifted thread to OT. But my point is still that I think cork Work Great for gasket in some situations.
I've always wondered about this, everyone is so engross in building a dead cabinets but I don't think I've read any thread on
preventing sound within the cabinet from reflecting onto the back of speaker cone. Isn't this far more important ?
