I've heard the Jubilee at the last Montreal audio show and was really impressed by the axi2050 combined with the K402 horns.
I use the BMS 4596 on my horns and after 7-8 khz there is nothing left on my 340hz jmlc horns, my JBL 2440 with radian diaphragm get to 12-15khz but it's too directional. Since I'm on a 3 ways it's much of a problem but getting the axi2050 I would have more play with where I need to put the crossover.
For me the axi2050 on a 2 way like the Jubiliee sounded better than anything at the snow, relax and sense of scale and never aggressive. I'm not a fan of the amplifiers they were using on them and the room was too long and narrow yet it still was the star of the show for me. The bass in the room was very good and impactful and properly integrated with the horns.
If I compare to my faital hf10ak and hf108r, the axi2050 once EQued (I'm pretty sure the crossover is used to compensate the HF output) sounded more natural and easier to lister to. The faital do get high in the frequency easily (no eq needed on my 1100hz azura horns) but I always get the feeling it's not very natural and lack resolution. Neither the axi2050 or the hf108 hf10ak are champion of resolution in HF but it can work in a 2 way setup and the axi2050 can be used on large horns really well where the faital can't. They are, in my opinion, better in the mid than berelium TADs (never liked the mids on those) while similar in the HF.
I need to find a pair of those celestion to test on my horns.
Insightful and recognizable comment that touches on the importance of system integration.
The superior material properties of Be are also the problem imo.
I have never listened to the TAD studio monitors (2402 etc.), but based on the material characteristics of the TL16.. woofers and the TD40.. compression drivers it's easy to see that these are literally 2 'separate worlds' that cannot possibly be forged into a homogeneous sounding whole.
Ok, some will argue, then you use 'superior' materials for all drivers, right?
Possible. After a major financial loss, you eventually may end up with something like this:
To put these aside after several unsatisfactory upgrades in the audio chain in order to enjoy 'natural sound' again.
Not really necessary to illustrate the difference in material resonances, especially in the treble (> horns are different).To be comparable, these should be normalised to flat... no? Which ti driver was this?
Drivers are DE500 and the older RCF.
Although the HF108 is not exactly 'clean' in the highest octave, the driver does sound pleasant.
The same applies to both titanium drivers (> described by professionals as 'warm sounding').
It's all related to material/mechanical properties.
Sorry, but you sound like you have no idea what you are talking about.I have never listened to the TAD studio monitors (2402 etc.), but based on the material characteristics of the TL16.. woofers and the TD40.. compression drivers it's easy to see that these are literally 2 'separate worlds' that cannot possibly be forged into a homogeneous sounding whole.
No offence intended!
Both those units (woofer and compression driver) use the best available materials for their intended pass-bands and applications.
Blending them into a homogeneous sounding whole is the job of competent crossover design.
Mine is that they sound fundamentally similar to the myriad of 1" dome tweeter + (multiple) small mid-woofer(s) slim towers that the market is flooded with.Your own experience with them?
With minor variations, of course.
But they sound NOWHERE near as realistic as a properly driven TAD studio monitor (and yes, I have listened to both).
i have to disagree too , before the the Faital HF108 ,i havre tried 18sounds 1095N TAD 2001 , and FAITAL HF10AK and the TAD was no better than the others 1inch driver sorry for the legend.. on the french melaudia forum there have compared the HF10AK and the 2001 and they mesures nearly the same ..
Except, that's a terrible horn plagued by diffraction. As such, its shortcomings will dominate and mask any audible or measurable differences between the two compression drivers...on the french melaudia forum there have compared the HF1010AK and the 2001 and they mesures nearly the same
One can't just casually and quickly "try" a range of drivers and expect to be able to say the last word on which is better...
this can also applies to yourself ..One can't just casually and quickly "try" a range of drivers and expect to be able to say the last word on which is better...
Agree 100%, the HF10AK is a very close match sound wise to the 2001. It is really very, very good. Cross it over properly and you will be amazed!i have to disagree too , before the the Faital HF108 ,i havre tried 18sounds 1095N TAD 2001 , and FAITAL HF10AK and the TAD was no better than the others 1inch driver sorry for the legend.. on the french melaudia forum there have compared the HF10AK and the 2001 and they mesures nearly the same ..
Not all that similar to the TD-2001, except for the dip in the response. the TD 2001 needs a high impedance source or a resistive padding for it to performs it's best, and that dip will disappear from it's response, as shown numerous times.
The Pioneer /TAD Polymer Graphite cones are a better/easier match to they're BE diaphragm drivers at least, no argument there. Although the TAD 16xx cones are free of the usual paper cone breakup/hash far beyond any other woofers I've seen. If you slice a TAD 16xx cone you will find a large amount of the cone is not actually paper, almost half it's thickness (by eye) is the damping material polymer/composite or similar.The superior material properties of Be are also the problem imo.
While not having the advanced modelling tools of today, they were still optimized for a clean response without breakup, by using optical laser measurements.
Hi Arez,
Kindest regards,
M
Would you please have any reference to this? I had read on one of the fora that the break-up free frequency was up to about 400 Hz; unfortunately no reference was provided. I am rather suspicious about that claim since TAD used the drivers with crossovers as high as 650 Hz (Pioneer Exclusive 2402).Although the TAD 16xx cones are free of the usual paper cone breakup/hash far beyond any other woofers I've seen.
Kindest regards,
M
You can see it remains very clean in terms of breakup far beyond usual 15-16" paper cone woofers. The linearity up to 1k is remarkably good.Look at post #934, although it is the extinct budget" ferrite woofer 03, it's cone is the same as the 1601b.Hi Arez,
Kindest regards,
The second pic linked is a "normalised" measurement.
Don't know where your info is from, the Response is not completely flat, but it is not because of paper breakup/hash, as is common with most paper cone woofers, the cones are as mentioned unusually well damped, with whatever polymer coating or similar that is used on them.
But they are not power handling monsters, and thermal compression is not they're strong side, meaning a lot of surface area/ smaller excursion and large enclosures, all going against modern tiny speakers.
Compare it to the factory response measurements of the 160X from they're manuals/tech sheet and you see very good coherence between them.
With a little DSP the Jubilees can sound and measure prettty good: https://community.klipsch.com/index.php?/topic/202770-klipsch-jubilee-and-dsp/
I use a JBL 2453H-SL 1.5" exit driver on a JBL 2384 waveguide. The aquaplas coating seems to work well. Sounds good, but always looking for better...
Hi Arez,
Kindest regards,
M
Thank you very much for the data.You can see it remains very clean in terms of breakup far beyond usual 15-16" paper cone woofers.
Kindest regards,
M
Same here, except it is the 2452 driver. Best I’ve heard.I use a JBL 2453H-SL 1.5" exit driver on a JBL 2384 waveguide. The aquaplas coating seems to work well. Sounds good, but always looking for better...
- Best Compression Drivers today 2022?
