HIP4080 amp - EVO 2200.1
Hi all,
I have a hip4080 amp in over current status.
No shorted mosfets.
tested a known working HIP4080 IC and issue persists.
Pic below of hip4080 area
dc voltage present on both positive and negative speaker terminals
Outputs - P60NF06 (used 65N06 for testing)
PSU - IRFZ44
4080 amps can be very finicky. Unless you know 100% for sure that those work in 4080 amps, they could be the problem.
Did you confirm that all drive signals at the FETs are good?
In the 90s I designed some medium power (10~20W) class-D-amps with HIP4081. They were the most unreliable amps I ever had, failing sporadically. At the end I ditched them all and gave up designing class D - until Texas Instruments came onto this scene.
