any news ?facts and internal pics arround different 2N3055
Motorola 2N3055 info and counterfeit watch
I am looking for the very first RCA papers/manuals/application notes from that time, where reportet about the 2N3055. Perhaps you know the exactly title and the date of release. About
http://www.diyaudio.com/forums/parts/167680-vintage-transistors-4.html
(go to post #33 and #34) I have posted some cover pics from old RCA books - perhaps one of this book is that, what I need.
Additional I want to have pics or URLs about the very first advertisement of the 2N3055 (about wikipedia I read, the date of release was in the early 60's, but I don't find the exactly date).
Perhaps you know this - thanks for advices.
I have a RCA transistor Manual Technical Series SC-11 copywrite 1964. It has a 2n3055 in it. Vceo 60 Ic max 15 A Pd case 25 C 115 w Vcesus (Rbe=0 Ic=.2A) 60 vcesat (IC=4 Ib=.4) 1.1v
Current transfer ratio (Ic=4 Vce=4) 20 to 70 . There are transfer curves and Vbe to Ib cirves.
No Ft spec.
FIgure 11-11 in the back, high quality 25 w audio amplifier, has push pull 2n2147 outputs and an interstage transformer after the 2n2148 input transistor.
I don't have a camera since they are all made now in a place I don't buy from.
I didn't start work in electronics until 1976 so I retrieved this book out of the trash.
No Ft spec.
This SC-11 manual is anywhere online here as I know (I had upload as PDF in post #246).I have a RCA transistor Manual Technical Series SC-11 copywrite 1964. It has a 2n3055 in it. Vceo 60 Ic max 15 A Pd case 25 C 115 w Vcesus (Rbe=0 Ic=.2A) 60 vcesat (IC=4 Ib=.4) 1.1v
No Ft spec.
But I am still looking for the very first announcements and advertisements for 2N3055 in electronic magazines so as brochures from RCA.
http://bitsavers.informatik.uni-stuttgart.de/components/rca/_dataBooks/1978_RCA_Power_Devices.pdf
from 1978, inside some schematics
Not exactly an amplifier, but I think it's worth posting it:
Here you can see the initial bitter flowers of the "importozameshenye/импортозамещение". This is the moment when the comrades realized that the crap USSR transistors can be replaced by the reliable Western ones
And all this process finally went to the point where there were no possible ways for building the Russian assault weapons except than using the Western IC/transistors/etc.
Hello tiefbassuebertr
Following a hunch I looked up a couple more mags.
Found one. Not the one I originally saw, but a full page ad.
Page 67 in Industrial Electronics magazine. Available on World Radio History, UK magazine section, January 1965.
Probably advertised in the USA previous year.
The 4B date code probably means February 1964.
I think in November 1996 they should have known that a supply voltage of ±50 V puts excessive stress on most of the involved semicinductors and that TR4 multiplies it's Vbe by a factor of not more than 3.3, while 4 Vbe's are needed to bias the power devices at all.Here is one my my Maplin 225WRMS amps.
Used 2n3055/mj2955.
Best regards!
I wonder why they didn't populate Czechoslovakian (Tesla) KD617's, which are superior than 2N3055's? And do you know what is shown in your pic?Not exactly an amplifier, but I think it's worth posting it:
Here you can see the initial bitter flowers of the "importozameshenye/импортозамещение". This is the moment when the comrades realized that the crap USSR transistors can be replaced by the reliable Western ones.
Best regards!
@Kay P - the Vbe you discuss does not mean that the quiescent current could not be set correctly. Your Vbe calculation assumes that all the Vbe's are the same. They might be if all the transistors were the same and operated at the same voltage and current, but they are different. The BD139 is running at a (guesstimated) 10mA, but the driver transistors are hugely over-rated - 75W, 12A and would pass a respectable current with a relatively low Vbe. The same for the output transistors. (Also, the drivers are epitaxial base 3MHz and not ideal. They seem to have worked in this application though. Probably chosen for 100V rather than high frequency)
You are correct in supposing that 4Vbe's are required, but in many circuits like this, that is not achieved. A different bias circuit could deliver the necessary compensation, but I suspect the quiescent current would be settable.
I built a few equa amps - it’s what got me going in electronics. 😊hello.
from elektor:
edwin, equa and equin - power amps in the seventies.......
harman kardon (citation)........
grüsse
Me tooI built a few equa amps - it’s what got me going in electronics. 😊
Best regards!
Thanks. Looks familiar and I recognise a lot in the circuit. I think the English language version came out a year or two later, but I might be mistaken.
Good memories. I knew nothing about grounding, wire routing or anything like that. Mine hummed!
Good memories though!
- 2N3055 inside - commercial famous amplifier models, quasi complementary power output
