New First Watt product at Axpona 2023
The real question is what will it be: a follower, a Mu follower, or something with a VAS on the front end.
I think it could be a bit still before we see something for us to build, so while I have devices burning a hole in my pocket I'm building the Singing Bush right now and after will build Ben Mah's follower.
For the greedy boys!
SIT-1 was single ended common source with resistor load, mono block, 10W at 8R
SIT-2 was single ended common source with CCS load, stereo, 10W at 8R
SIT-3 was DEF push-pull, stereo, 18W at 8R
SIT-4 10W at 8R and "Glorious Triode Sound": Probably not a repeat of SIT-1 or SIT-2, but then "Glorious Triode Sound" to me means a certain amount of second harmonic distortion. So what is left is common source with choke load, or some sort of common drain single ended, but common drain has less of the "Glorious Triode Sound".
