CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc
Camilladsp doesn't really integrate with coreaudio, instead it just opens one device for recording (BlackHole), and one for playback (your dac). CoreAudio offers several more advanced ways to hook into the audio stream but using thise doesn't fit well in a cross platform project like this.
The coreaudio api is large and quite complicated. Unfortunately the documentation from apple is very poor. The header files are a little better but a pain to navigate. I have mostly looked at the sources of other projects (such as cpal) to figure out how things are done. There may be some books that could help (I have not looked).
Hi Henrik,
Thank you very much for your informative reply. Now it appears that I just need to design FIR filters for all 6 sample rates from 44.1kHz to 192kHz. Your help is greatly appreciated for figuring out the difficulty and set the easy direction. 🙂
Jay
Then there is the problem to switch between these filters - there is no such native support in Camilla. It was discussed at an early(ier) stage in this thread. I recall one member did some programming to accommodate the switching.
In my oppinion it is best to let CamillaDSP resample any input sampling rate to one and the same sampling rate.
1. Because then you have the control of the resampling quality. The CamillaDSP config resampler quality options are already very refined by today, and even more quality options and variants are to come in V.2. Stay tuned an look forward ...
2. You can choose the resampled rate your DAC likes best.
3. You only need one set of filters for all incoming rates. If the incoming rate does not match the configured one, then you can let CamillaDSP crash, adapt the configuration to match the actually incoming audio and then let CamillaDSP restart again. No need for filter switching.
This approach works very well for me in an audio gadget Rpi: Audio_Host_USB_any_rate_out -> USB_Gadget_CamillaDSP_resampling_and_filtering -> SPDIF out -> DAC_in.
By the way: I would strongly advocate to try out a dedicated USB CamillaDSP gadget solution wherever possible. The current linux kernels (>5.18) now are fully functional, and the setup of a gadget is quite straightforward.
Starting trail...
I have been away for a while and am getting back into my audio rig.
Has there been any issues with alsa_cdsp lately ?
I have started to get some intermittent audible glitches after upgrading my Debian install that I need to investigate.
Code:
6.1.0-0.deb11.5-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.12-1~bpo11+1 (2023-03-05) x86_64 GNU/Linux
I also see there has been patches made to bluez-alsa with respect to making pcm variables thread safe that should be investigated.
One bluez-alsa patch
I will post whatever I find.
Thanks much.
Hi Henrik,
Thank you so much for creating and maintaining CamillaDSP!
Is there a way to shift a channel's phase by 90 degrees? I would like to decode signals from quadraphonic LPs.
Thanks,
David
If you want to change JUST phase, this will get you close, but there is some increase in phase in higher frequencies.
If anyone knows of a better way to do it in RePhase (without the high frequency roll), please chime in.
The xxx.RePhase file is in the attached zip file so you can change it to +/- 90, specify sampling rate, output format, # taps, etc. as you require.
Best process to compare FIR filters with "matching levels" ?
I just have installed CamillaDSP under Moode. I have several FIR filters to compare (min phase, lin phase, different corections...). How to "level match" the different filters so that they play at the same percieved level (rougthly , to reasonnably limit volume bias) ?
How to "measure" the filter "gain"? How to align that gain between the different filters?
I understand that this may not be CamillaDSP specific.
Best regards,
JMF
Create a config for one and each filter in Camilla. Measure with voltmeter at say 1khz for each filter (after preamp or maybe even at speaker terminal) - doesnt matter its just relative levels - and adjust attenuation in Camilla per config too match levels?
You want better than 10mV for less then 0,1 dB diff - and you do if for a relevant comparison 😉
http://www.sengpielaudio.com/calculator-gainloss.htm
Well, if the FR is not straight then all bets are off - on the other hand - if so, something else if dubious to say the least...
But, if you do it like that and hear some differences - well, there you have it - yous spotted it ;-D great - misson accomplished.
IRs are normalise to 1 - so no...
@HenrikEnquist is it possible to have re-usable fragments of a YML file for IIR filters (aka include similar to FIR filters specifying a path to parameters)?
What I want to do, is create my 6 channel crossover filters once and also pipeline, but have different YML files for an upstream EQ setting, before going to the crossover.
At the moment, I have to repeat the crossover filters and pipeline in each YML for a different EQ.
