Moode Audio Player for Raspberry Pi
Bonjour
Excuse mon anglais.
J'ai un problème avec Moode et l'écran officiel.
au bout d'une heure environ l'écran se met en veille profonde impossible de le réveiller même avec l'interface web.
seule solution redémarrer le Pi.
si quelqu'un a une réponse.
MERCI
Ok
S Y S T E M P A R A M E T E R S
moOde release = 8.2.0 2022-09-16
RaspiOS = 11.3
Linux kernel = 5.15.84-v7+ #1613
Platform = Pi-3B+ 1.3 1GB
Architecture = armv7l (32-bit)
System uptime = up 2 minutes
Timezone = Europe/Paris
Current time = 2023-04-01 15:02:03
Host name = moode
Ethernet address = unassigned
Ethernet MAC = b8:27:eb:82:86:cf
WLAN address = 192.168.1.35
WLAN MAC = b8:27:eb:d7:d3:9a
WLAN country = FR
WLAN AP SSID = Moode
WLAN AP chan = 6
WLAN AP router = Off
SoC identifier = bcm2837
Core count = 4
Kernel timer freq = 100 Hz
SDCard freq = 50 MHz
USB boot = enabled
Warranty = OK
Root size = 15G
Root used = 19%
Root available = 12G
Root expand = expanded
Memory total = 944 MB
Memory free = 693 MB
Memory used = 251 MB
SoC temperature = 35.4°C
Throttled bitmask = 0x0
Throttled text = No throttling has occurred
CPU governor = ondemand
Onboard WiFi = On
Onboard BT = On
HDMI output = On
LED state = 1,1
IP addr timeout = 90 (secs)
Ethernet check = No
USB auto-mounter = udisks-glue
SSH term server = Off
SMB file sharing = Off
NFS file sharing = Off
NFS access =
NFS options = 192.168.1.35
PHP-FPM version = 7.4.28
NGINX version = 1.18.0
SQLite3 version = 3.34.1
Hostapd version = 2.9
RPi.GPIO version = 0.7.0
A U D I O P A R A M E T E R S
Audio device = Allo DigiOne
Interface = I2S
Mixer name = none
Hardware mixer = No
Supported formats = S16_LE, S24_LE
ALSA max volume = 100
ALSA output mode = Default (plughw)
ALSA loopback = Off
MPD max volume = 100
Volume step limit = 10
Display dB volume = Off
Audio source = Local
Output device = Local
Resume MPD = No
Volume knob = 0
Volume mute = Unmuted
Saved MPD vol = 0
Preamp volume = 0
ALSA version = 1.2.4-1.1+rpt2
SoX version = 0.1.3-4+rpi1
Bluetooth controller = Off
Pairing agent = Off
Airplay receiver = Off
Spotify receiver = Off
Squeezelite = Off
RoonBridge = Not installed
UPnP client = Off
DLNA server = Off
GPIO button handler = Off
Multiroom sender = Off
Multiroom receiver = Disabled
Auto-shuffle = Off
Ashuffle mode = Track
Ashuffle filter = None
Autoplay = Off
Rotary encoder = Off
Encoder params = 100 2 3 23 24
USB volume knob = Off
Polarity inversion = Off
Crossfeed = Off
Crossfade = Off
Parametric EQ = Off
Graphic EQ = Off
CamillaDSP = off
MPD httpd = Off
Ignore CUE files = Yes
P R E F E R E N C E S
Appearance
Theme = Pure Black
Accent color = Emerald
Alpha blend = 1.0
Adaptive background = No
Background image = No
Cover backdrop = No
Cover blur = 20px
Cover scale = 1.25
Renderer backdrop = No
Font size = X-Large
Native lazyload = Yes
Playback
Show Queue thumbs = Yes
Show Now-playing icon = Yes
Show CoverView playbar = Yes
Show extra metadata = album,genre,track,disc,date,composer,conductor,performer,encoded
Search site = Google
Playback history log = No
Library
One touch album = Play
One touch radio = Play
One touch playlist = No action
Albumview sort order = by Artist
Tagview sort order = by Artist
Track play = Track
Recently added = 1 Month
Show sample rate = No
Cover search pri = Embedded cover
Pixel ratio = 1
Thumbnail resolution = 600px,60
Thumbnail columns = 8/4
Library (Advanced)
Tag view genre = Genres
Tag view artist = Artist
Album key = Album@Artist (Default)
Include comment tag = No
Library filter = full_lib
Library filter str =
Ignore articles = a,an,the
Show tagview genres = Yes
Show tagview covers = Yes
Ellipsis limited text = No
UTF8 character filter = Non
CoverView
Timed display = Never
Automatic display = -off
Backdrop style = Noir pur
Display mode = Couverture
Display layout = Défaut
R A D I O M A N A G E R S E T T I N G S
Sort tag = Name
Group method = No grouping
Show moOde stations = No action
Show other stations = No action
P L A Y L I S T M A N A G E R S E T T I N G S
Sort tag = Name
M P D S E T T I N G S
Version = 0.23.5
Volume type = null
SoX resampling = disabled
Selective resampling = disabled
SoX quality = medium
SoX multithreading = off
DSD over PCM (DoP) = no
Replaygain = off
Replaygain preamp = 0
Volume normalization = no
Audio buffer = 4 (MB)
Output buffer size = 128 (MB)
Max playlist items = 16384
Input cache = Disabled
B L U E T O O T H S E T T I N G S
Version = 5.55
Bluealsa = v3.0.0
Pairing agent = 1.0.0
Pi-Bluetooth = 0.1.19
Speaker sharing = No
Resume MPD = No
PCM buffer time = 500000 (µs)
A I R P L A Y S E T T I N G S
Version = 3.3.8
Friendly name = Moode Airplay
Interpolation = soxr
Output bit depth = S16
Output sample rate = 44100
Session interruption = no
Session timeout = 120 (ms)
Latency offset = 0.0 (secs)
Audio buffer = 0.2 (secs)
Resume MPD = No
S P O T I F Y S E T T I N G S
Version = 0.4.2
Friendly name = Moode Spotify
Bitrate (kbps) = 160
Format = S16
Dither = Automatic (Default)
Volume curve = log
Volume range (dB) = 60
Initial volume (%) = 0
Volume normalization = No
Method = dynamic
Gain type = auto
Pregain (dB) = 0
Threshold (dBFS) = -2
Attack (ms) = 5
Release (ms) = 100
Knee = 1
Autoplay = No
Resume MPD = No
S Q U E E Z E L I T E S E T T I N G S
Version = 1.9.8-1317 "DSD/SRC enabled"
ALSA device = hw:0
ALSA params = 80:4::1
Output buffers = 40000:100000
Task priority = 45
Codec list = flac,pcm,mp3,ogg,aac,alac,dsd
Other options = -W -D 500 -R E -S /var/local
Resume MPD = No
L O C A L D I S P L A Y S E T T I N G S
Local UI display = On
Mouse cursor = Off
Screen blank = 600 Secs
Wake display on play = On
Brightness = 100
Pixel aspect ratio = Default
Rotate screen = 0 Deg
M O O D E S T A R T U P L O G
20230401 142208 worker: --
20230401 142208 worker: -- Start moOde 8 series
20230401 142208 worker: Successfully daemonized
20230401 142211 worker: File check (OK)
20230401 142212 worker: Session vacuumed
20230401 142212 worker: Session loaded
20230401 142212 worker: Debug logging (ON)
20230401 142212 worker: --
20230401 142212 worker: -- Audio debug
20230401 142212 worker: ALSA cards: (0:sndallodigione | 1:empty | 2:empty | 3:empty
20230401 142212 worker: MPD config: (0:Allo DigiOne | mixer🙁none) | card:0)
20230401 142212 worker: ALSA mixer actual (none)
20230401 142212 worker: ALSA volume (none)
20230401 142212 worker: -- System
20230401 142214 worker: Host (moode)
20230401 142214 worker: moOde (8.2.0 2022-09-16)
20230401 142214 worker: RaspiOS (11.3)
20230401 142214 worker: Kernel (5.15.84-v7+ #1613)
20230401 142214 worker: Platform (Pi-3B+ 1.3 1GB)
20230401 142214 worker: ARM arch (armv7l, 32-bit)
20230401 142214 worker: MPD ver (0.23.5)
20230401 142214 worker: CPU gov (ondemand)
20230401 142214 worker: USB boot (enabled)
20230401 142214 worker: File sys (expanded)
20230401 142214 worker: HDMI port (On)
20230401 142214 worker: Sys LED0 (On)
20230401 142214 worker: Sys LED1 (On)
20230401 142214 worker: --
20230401 142214 worker: -- Network
20230401 142214 worker: eth0 adapter exists
20230401 142214 worker: eth0 check for address (No)
20230401 142214 worker: eth0 address not assigned
20230401 142214 worker: wlan0 adapter exists
20230401 142214 worker: wlan0 country (FR)
20230401 142214 worker: wlan0 trying configured SSID (Bbox-76060B1C)
20230401 142214 worker: wlan0 check 0 for IP address
20230401 142217 worker: wlan0 check 1 for IP address
20230401 150021 worker: wlan0 connected SSID is (Bbox-76060B1C)
20230401 150021 worker: IP addr (192.168.1.35)
20230401 150021 worker: Netmask (255.255.255.0)
20230401 150021 worker: Gateway (192.168.1.254)
20230401 150021 worker: Pri DNS (192.168.1.254)
20230401 150021 worker: Domain (lan)
20230401 150021 worker: wlan0 power save disabled
20230401 150021 worker: apd0 router mode (Off)
20230401 150021 worker: --
20230401 150021 worker: -- Software update
20230401 150021 worker: Automatic check (Off)
20230401 150021 worker: -- Audio config
20230401 150021 worker: MPD conf updated
20230401 150021 worker: ALSA card number (0)
20230401 150021 worker: MPD audio output (Allo DigiOne)
20230401 150022 worker: Audio formats (S16_LE, S24_LE)
20230401 150022 worker: ALSA mixer name (none)
20230401 150022 worker: MPD mixer type (null)
20230401 150022 worker: Hdwr volume controller not detected
20230401 150022 worker: ALSA output mode (Default: plughw)
20230401 150022 worker: ALSA loopback (Off)
20230401 150022 worker: Reset renderer active flags
20230401 150022 worker: CamillaDSP (off)
20230401 150022 worker: --
20230401 150022 worker: -- File sharing
20230401 150022 worker: SMB file sharing (Off)
20230401 150022 worker: NFS file sharing (Off)
20230401 150022 worker: -- MPD startup
20230401 150022 worker: MPD started
20230401 150022 worker: MPD accepting connections
20230401 150023 worker: MPD output 1 ALSA Default (On)
20230401 150023 worker: MPD output 2 ALSA Bluetooth (Off)
20230401 150023 worker: MPD output 3 HTTP Server (Off)
20230401 150023 worker: MPD crossfade (off)
20230401 150023 worker: MPD ignore CUE files (yes)
20230401 150023 worker: --
20230401 150023 worker: -- Music sources
20230401 150023 worker: USB sources (none attached)
20230401 150023 worker: NAS sources (none configured)
20230401 150023 worker: -- Feature availability
20230401 150023 worker: Source select (available)
20230401 150023 worker: Source select (source: MPD)
20230401 150023 worker: Source select (output: Allo DigiOne)
20230401 150023 worker: Bluetooth (available)
20230401 150023 worker: Airplay renderer (available)
20230401 150023 worker: Spotify renderer (available)
20230401 150023 worker: Squeezelite (available)
20230401 150023 worker: RoonBridge renderer (not installed)
20230401 150023 worker: Multiroom sender (available)
20230401 150023 worker: Multiroom receiver (available)
20230401 150023 worker: UPnP renderer (available)
20230401 150023 worker: DLNA server (available)
20230401 150023 worker: GPIO button handler (available)
20230401 150023 worker: Stream recorder (n/a)
20230401 150023 worker: -- Other
20230401 150023 worker: USB volume knob (Off)
20230401 150023 worker: USB auto-mounter (udisks-glue)
20230401 150023 worker: Saved MPD vol level (0)
20230401 150023 worker: Preamp volume level (0)
20230401 150023 worker: MPD volume level (0) restored
20230401 150023 worker: ALSA volume level (None)
20230401 150023 worker: Auto-play (Off)
20230401 150023 worker: LocalUI started
20230401 150023 worker: CoverView toggle (-off)
20230401 150023 worker: Maintenance interval (360 minutes)
20230401 150023 worker: Screen saver activation (Never)
20230401 150023 worker: Session permissions (OK)
20230401 150023 worker: Watchdog started
20230401 150023 worker: Ready
20230401 150155 waitWorker(): Start (sys-config, w_active=0)
20230401 150155 waitWorker(): End (sys-config, w_active=0)
@aditya
@anounaki
@TimCurtis
Hi!
I had been meaning to update to the new version on a new SD card anyway, so I tried it.
And I got similar results: the local touchscreen no longer works with the UI.
Double checked the display cables.
I used the Raspberry PI imager:
  • enabled SSH
  • set user id and password
  • set up wifi
Results:
  • Boot up seems fine
  • I see the four raspberries and the scrolling text
  • It does stop and ask for a TTY1 login, but then continues on
  • Then resets to a blank screen
  • the web interface works
  • SSH works
Settings I tried:
  • "Wake on play" to "ON"
  • "Screen blank" to "Never"
  • "Cover View" to "On"
  • "Local UI" restarted.
  • Even "LCD updater" to "ON" (does that have anything to do with an HDMI output?)
And, just to see if changing something here might jiggle something elsewhere, I also went through changing some Preferences. I tried:
  • "Timed display" to "1 minute"
  • "Automatic display" to "Yes"
  • "Backdrop style" to "Pure Black"
  • "Display mode" to "Analog clock"
  • "Layout" to "Wide"
  • "CoverView playbar" to "Yes"
  • "Extra metadata" to "Yes"
While I know you don't support anything other than the Official touchscreen, this seems to be three in a row (not sure how @anounaki fixed his issue). So I am posting the two files just in case someone else finds something. (I will try doing a diff with @frider posting, but I am on a chromebook today).
Reactions: aditya
Results:
  • SSH works
Settings I tried:
@CANNON-FODDER
I have done all of these above steps, but alas, Yes i also wonder how @anounaki managed to get lucky. Which display do you use and which display does anounaki use.
I am using the 800 * 480 7" DSI based WaveShare display, And i have previously used it on Moode and PCP, Volumio, rAudio, Hifiberry OS - with zero issue except some were sluggish to touch and work on.
Few mounths back i managed to do a transfer of the Main Display board( 7" Wave Share DSI 800 X 480) on to the 7" official display since my original display's driver board is shorted, but the display worked perfectly.
My Guess - Waveshare made the display for RPI and than release its own line up of DSI displays Coz why would otherwise the Display cable be having the same pinout as the Original RPI 7" Display ( not the DSI cable pinout but the big FLex cable that goes to the Display board from the LCD display )
Hi @CANNON-FODDER
thats a normal HDMI display and i think you should get a display by default unless i am missing something, just check iff "HDMI" slider is on the onposition and keep "Local Display" slider in off position.
after doing the above, power on the unit without the display connected, and once is up and running connect the display and observe..
My display connect to the Cream colored connector above the micro SD card.. so that is a DSI display..
@TimCurtis @CANNON-FODDER
Luckily I had not formatted my working Moode card and used another 64Gb card for checking out other builds.
This Moode 8.2.5 runny my local wave share 7” dsi display.
Not sure why Moode 8.3.0 won’t display.
Me? Or something has change somewhere
