expensive open baffle woofer solutions: AE LO12 or ScanSpeak 32W/4878T11 or 4x Purifi PTT8.0?
@Draki; thanks, I had misunderstood. I thought the rear facing drivers were in the same vertical line as the forward facing ones but they are off to the side, hence the offset 🙄.
Apologies CharliLaub for dragging your thread OT. I’m looking forward to the article too. I’m interested because I also want my planned speakers to be the end game for me.
If you go high end. Then the scan speak 32w/4878t00 has lowest low bass distortion i have seen any tests. And it is good to have high xmax at open baffle use.
Cheap solution would be twin ciare hs251. You can connect voice coils series to get high qts. Also woofer has low low bass distortion and high xmax.
Yes indeed. The 32W/4878T00 looked very impressive in the VoiceCoil review from 2013 . The motor is amazing. I assumed that the 32W/4878T11 has a similar motor but with flux focused in a narrower gap but I have not seen Klippel tests that would verify that. They both cost almost US$700, so much more expensive than the Seas L26RO4Y but also 12" vs 10".
Reactions: Arez
For a woofer It has nice and extended response past 1KHz.
I'm haven't seen any real stress tests. ie. measurements purely focused on performance in the bottom octave.
Voice Coil test bench (2013) measured @94dB @1m from 50Hz and up
Klang and Ton measured @95dB @1m again, from 50Hz and up.
But 50Hz and up, and at those SPLs, well it’s relatively gentle (<10W), its hard to separate from other good 12" subwoofers.
Only Hobby Hifi measured @20hz and up (90dB@1m) and in that one it didn't really distinguish itself.
A great book;
Or coffee table book for loudspeaker nerds:
https://audioxpress.com/article/the-danish-loudspeaker-100-year-anniversary-book
In my view; Peerless ceased to be a Danish manufacturer the day an American group of investors bought out Danish Sound Technology; (a holding company of Scan-Speak, Vifa and Peerless) and renamed it Tymphany:
This was almost 2 decades ago-
http://www.zaphaudio.com/tymphany.html
Some Vifa employees left and respawned as Wavecor. Some Peerless employees left, formed other compnanies and are now at Purifi. Some Scan-Speak employees left and eventually bought back the tooling/rights for Scan-Speak drivers. Some Scan-Speak employees formed Gamut (loudspeaker manufacturers) or ScAR (Scandinavian Audio Research) or Danesian Audio. The latter formed a partnership with Sinar Baja Electric and became SB Acoustics.
It’s all very complicated because the Denmark has a rich history and heritage as one of the pioneers of the dynamic loudspeaker with voice coil. In fact Vifa was formed out of some disagreements of SEAS, and Dynaudio, Scan-Speak and AudioTechnology were all founded by the fellow company.
Up until the late 20th century loudspeakers was Denmark’s third biggest export by revenue.
Interesting project CharlieLaub. I have experience with 2 of the drivers mentioned. I have used the 2layer voice coil variant of the Seas L26ROY. This Seas has tons of excursion and also low 2nd harmonic distortion in the 30-40hz range. This helps out in the real world as most domestic rooms with a 8-9 ft ceilings have room modes in the 60-80hz range. However to be honest, I do not like the upper bass from the Seas it has a distorted metallic edge to it.
Multiple Purifi 8" or waiting till the 10" is available would probably be my choice for your project. Dipole bass is very demanding of the driver and the Purifi remains clean at high drive levels. I have compared the IMD of the Purifi 8" to the Seas 10" and the Purifi is cleaner in all tests. I don't foresee the 4 layer Seas to do better in IMD as according to Seas the 2 layer variant has lower distortion. https://www.diyaudio.com/community/...lation-distortion-testing.387690/post-7249113
I don't have experience with the LO12 but I have used the AE IB15HT in dipole and the AE SBP12a in a sealed box. To give an idea of the demands of a dipole system 2 15" woofers about equal a single monopole 12". Attached is the 30 and 72hz IMD test of a pair of AE IB15HT woofers compared to a single AE SBP12a in a 85 liter sealed box. I have used the trick that Steinway uses to reduce even order distortion and one of the 15" drivers is reversed mounted with polarity flipped. You see in the graph that the 2nd harmonic distortion of 30hz(60hz) is almost lost in the noise for the dipole. The IMD3 at 132hz is about the same about -35db in all test. I'm not sure about using an underhung topology in a dipole, Mr. Linkwitz dismissed it many years ago: https://www.diyaudio.com/community/...st-bass-i-have-ever-heard.163914/post-2209229
I have no experience with ScanSpeak drivers but comparing the ScanSpeak 32W/8878T11 to the Purifi 8" on HifiCompass the Purifi has lower IMD levels.
Reactions: ianbo and lrisbo
When considering the AE LO series, be aware of one thing.
They do not like being overdriven, short underhung coils, so the THD goes up very quickly after a certain amount of excursion.
And it might be noticeable in some cases. That was the conclusion from Nick Mckinney (the designer) in a thread i read recently, just can't remember where.
I assume this might have been the older measurements your referenced to with the 15LO?
What i mentioned is quite visible in the Xmax measurements, as THD% if you compare the TD15 LO and X there.
https://sites.google.com/site/drivervault/driver-measurements/15
The upper end looks good, but it has the traditional cone/surround/frame dip as the other TD driver exhibits, just less prominent.
Not so different from the TD15M with it's quoted 6mm xmax, as shown at databass and a few other measurements, the suspension is not linear at those excursions. And the original spec of 3,3 mm from Lambda is more in it's comfort zone.
Reactions: asshatter
Studley, good question. Asymetric nonlinearity, such as having more motor force when going out versus going in is one of the causes or even order distortion. If you flip one driver and reverse the polarity, one driver is moving in while the other is moving out. Any asymmetries can therefore be cancelled to a certain degree. This causes causes a reduction of even order distortion.
OK thanks for that. Has this type of asymmetric behaviour been measured in many drivers and is it considered to be a significant source of distortion? I use the word significant in the sense of worthy of addressing.
I confess I thought the Model B arrangement was purely to allow a more compact construction.
I tried a number of 15, 18, and 21" pro drivers last year and I was not satisfied with most. By "try" I mean buy, and that gets expensive. The only one I found to work OK was a JBL 2268H, and I am using that in a system now. That driver is used nude, without a baffle, but being an 18 that is essentially the baffle size. So I want to keep the driver at 12" or less and put that in a baffle.
The vibration issue is not all that bad in my design. The woofer "panel" does not contain any other drivers and sits on the floor, so it is relatively stable. I cross over to subs around 70-80Hz so the driver excursion is not extreme nor is panel movement. The other drivers are 100% mechanically isolated from the woofers.
What was it about the pro drivers you tried that didn't work so well? I've been thinking about a similar OB woofer project. I haven't bought drivers yet, but I'd been thinking that pro drivers were the obvious way to go!
