Q17 - an audiophile approach to perfect sound
Hello,
I made a drilling plan for the Q17-Turbo. The board can fit in a 90mm height chassis.
Q17-TURBO-Drilling.pdf
A minimum of 6 holes must be drilled.
Have a nice week-end,
Stef.
Reactions: HRDSTL
Hello stef,
Didn't you measure the Slew Rate of the Q-17 Turbo? It would be interesting to know ...
Does the selection of the capacitor at position C7 affect the resulting sound quality?
I'd like to order the PCBs (Q17-Turbo) next month. 🤔
Thank You!
Hello Tibi,
In JLCPCB I put into production the latest PCB version (2.8), for the Q17 amplifier for 2 pairs of transistors.
The coil was designed with very small gaps, so the JLCPCB had to enlarge the gap for me. It threatened to merge...
PCBs are already at home, so I hope it will be OK after modifying them!
The plates are made of 2U thick copper.
Reactions: Captain B
Hello,
I intend to match my stock of FQA transistors. I intend to mount the FQAs on my second board by matching the FQA transistors and see if that changes a few things (for the better) in the measurements (distorsion).
Do you think the usual value of 170mA to match is ok for this or would it be useful to use another value more suitable for Q17?
Stef.
Steff,
In the end I'll go for your 1.3 mini version because I like it better and it's more compact. PCBs (2oz) from JLCPCB are already on their way to me, ...
Today I also finished the speaker protectors that I will use on the Q17. If anyone wants I can provide the gerber files.
For +50V power supply must be used stabilizer with LM317HVT designation
Hello,
You can always disassemble the components later if you change your mind. 😵
Best match for C7 here : https://www.ebay.fr/itm/164258731098
To my knowledge, these are the only ones to have Wima MKP2 1uF in stock.
Stef.
EDIT: I also received the two models of speaker protection too. The big one I knew and a little cheap version for less powerful amps.
Hello,
Stef.
The output of the relay should be of the highest quality, which can not be said about the ones from aliexpress, ...
Realized the order in farnell today and ordered all the active parts. The last item should be stocked by may, so hopefully by summer we'll be listening!
I would still like to suggest to Q17 a simple power supply (incl., 2x diode bridge, 4x filtration 35mm diameter, 2x fuse)...
