Salas SSLV1.3 UltraBiB shunt regulator
Reflektor-D is optimized for lower Vo already. L-Adapter can also go there. Modification in the Ubib can be tried by changing M2 to logic level like the IRL530 and using one red LED only but I am also worried about resulting in far too squeezed voltage margins for some JFETs in this. I.e. It could possibly manage but I am not sure if as good as you already like it at 5V.
Hi Salas, long time, hope all is well. I need a new psu for my MiniDSP 2x4HD. It doesnt need much, well below an amp 12 vdc. It comes with a wallwart of 800 mA but the consumption is rather mA. L-pad seems a bit overkill, what do you say? I need to ground and lift the psu anyway to get rid of a loop so I thought I’d diy something.
Reactions: vgeorge
Yes, I like it. I do not leave it on all the the time. Consumption is much lower and I think that it's a better solution for this use than an ultrabib.
I also use them to power my raspberry player, my nuc pc that I use to play files and for the 8V supply on my shigaclone cd transport. It is very versatile.
Reactions: stajo
Hi, nice to see you posting. All is well. As Vgeorge advised the L-Adapter PSU is most adequate for the consumption pattern of such devices. Well liked and made by many.
Reactions: stajo
