An open source layout for LM3886?
thanks for the explanation. I looked at a few other amplifier schematics and you are correct, they seem to all use a bi-polar cap, what confused me is most use a film capacitor, which by nature is bi-polar. I think in this design, the electrolytic is used strictly because of space restrictions. Luckily I had a bi-polar sitting around, so I installed that in place of the one I ordered. I will start with some testing on the protection board, before placing it into full-time use.
You can use a polarized capacitor (connected in either series or shunt), if there is enough DC voltage bias
on it so its polarity will never reverse. For example, used as an output DC blocking capacitor in a single ended circuit.
Has anyone built and used this protection circuit in a build? I build one (only substitution on BOM is MPS42/92 for the BC546/556 - reversed orientation on board), but when I power up it seems to be working in the opposite of what I think should be normal operation - no delay coming on and about a 2-3 second delay turning off. The other issue is I've tried to induce a DC to create a fault condition - nothing happens??? I have tried with DC power voltage to the board of 12-30V and inducing DC on the output from 1.5-9.5Vdc. I get no disconnect from the input to outputs on the board and no fault indicator LED lights.
Any insight on what might be the issue.
Reactions: pbilous
So I guess this means no one has made this protection board and got it working? I replaced the substituted A42/A92 for the spec'd 546/5556 and continues to come on immediately, delayed shut off and has not trigger to disconnect either connection to the speaker and the LED does not light. Would appreciate some assistance, anything to try, since I went to the trouble of ordering boards and have a build I was planning these speaker protection. for.
TIA!
Speaker Protection is working!!
Unsure if I had a bad solder joint, or if it was all from a faulty LED, but after re-working the solder connections on most of the board and replacing the LED - the protection board is working on my test bench. I have tested with supply voltage of 12-31vDC, while introducing DC on the outputs of 1.5-9.5vDC and it works without any issues. Will take some time to re-work the wiring in my amplifier I had these planned for, I put in other protection boards while I was working through these issues.
Can you please share the link to this speaker protection project?
I was intending on getting them done from JLCpcb, but shipping period and charges have increased a lot due to current pandemic. So will etch pcbs.
If you could guide about connection between layers, how to stitch them.
Me too in India and keen to build this. Im actually looking for something that includes the speaker protection.
Ping me I have some local contacts who deliver in a week and their prices are on par with JLPCB. So no customs duty.
Im in Bangalore. But my PCB guy is in Pune. And one guy is in Gujarat.
@intakto I believe there is a pretty barebones parts list in the project files but it'll just have values IIRC.
Here are the parts I ordered from mouser for the protect board:
https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=81a9380f94
I may have ordered extras of a few things in there. Can't remember exactly. Everything works great tho. Super happy with it.
I used a different PSU so can't help there. I reckon there would something with the values needed in the build files.
Hey thanks,
This list might be of use to someone.
NameDesignatorFootprintQuantityManufacturer Part
bipolar 10ufC1E2,5-71UVP1H100MED
1N4148D1,D2,D3,D4DO41-7.641N4148-DIO
TVS DiodesD5P2-151P6KE200A
LED5MMLED1LED5MM1Fault indication LED
BC546BQ1,Q3TO92-EBC2BC546B
BC556AQ2,Q4,Q5TO92-EBC3BC556A
IRFB3607Q6,Q7TO220BV2IRFB3607
100kR1,R56,3-2,3 mm2
22kR26,3-2,3 mm1
22kR3,R46,3-2,3 mm2
220kR6,R86,3-2,3 mm2
8k1R76,3-2,3 mm1
3kR96,3-2,3 mm1
TLP3906U$1SO-61alternative APV1121S
22-27-2021-02J46410-021molex connector
For the psu i garhered this.
PCB holes for KBU packageB225A/400V KBU2504-G or the 15A/400 GBU15G.
PCB holes for GBU4 packageB3
Aluminium Electrolytic CapacitorsC1,C2,C3,C4,C5,C6,C7,C850volts 2200uF 18x35.5 20% 7.5LS
Film Capacitors 0.01uF 100volt 10% RoHS CompliantC9,C10C050-025X075
Film Capacitors 0.15uF 63volts 10% RoHS CompliantC11,C12C050-025X075
Terminals 250 PCB TABJ1,J2,J3,J4,J5,J6,J7,J8,J9,J10F061.100
LED5MMLED1,LED2LED5MM
R-EU_0309/VR1,R2**
Metal Film Resistors - Through Hole 1/2W R3,R48.06Kohms 1% should be ok depends on rail voltage
OHMITE-RA-T2XHeatsink OHMITE-RA-T2X later posts suggest Ohmite RA-T2X-38E
22-27-2021-02J11,J12molex connectors
MKDSN1,5/2-5,08X1,X2,X3,X4,X5
As far as snubber networks go neurochrome notes that it is an exercise in futility as it makes not impact on performance. Most of the designs use 1 ohm but in the rectification and snubbers article, 10 ohms was used so it was also highlighted that exact values are not critical. For 150nf let's say a 6.8ohm resistor can be used. I am starting from 0 on this so i have no left over psu or anything 😉
