What is the audio info for the file you are trying to play? Click on the time for the track then audio info (bottom of the list).
I think he is asking for what shows up when you go to the little m on the upper right, and select "Audio Info".
Edit, strange, that last post didn't show up until just now, but seems to be time-stamped last night.
I realize the question about the Audio Info was regarding another post, but I tried looking at Audio Info when playing one of the problematic streams and nothing happens, I never see the Audio Info screen. Switching to a properly working stream, Audio Info displays correctly.I am running the latest version of Moode on Pi with a display and having an issue with Cover View mode. Metadata does not update on the screen for radio stations that I have edited. For example, I changed the streaming URL for Sonic Universe to the higher resolution stream, and now the station graphic, song title, etc. does not update on the screen. It permanently shows the metadata from the last unedited station and song played, and a generic MoOde graphic. Thoughts?
When you change a station URL it doesn't update any occurrences of the station in the Queue. Just remove the old station from the Queue and re-add the updated one and you should be all set.I am running the latest version of Moode on Pi with a display and having an issue with Cover View mode. Metadata does not update on the screen for radio stations that I have edited. For example, I changed the streaming URL for Sonic Universe to the higher resolution stream, and now the station graphic, song title, etc. does not update on the screen. It permanently shows the metadata from the last unedited station and song played, and a generic MoOde graphic. Thoughts?
Hello Tim, a friend of mine added all songs of library in queue and now player is completely frozen and does not react on anything. Is there a way to clean up queue? Thank you very much for reply in advance.
thank you all i tried reinstalling and moode played the DSD fileWhat is the audio info for the file you are trying to play? Click on the time for the track then audio info (bottom of the list).
audio stops after ca. 50 minutes
get an error: mpd error
If i press again "play" then sound goes on again for 50 minutes
Raspi3 with hifiberry = no problems
Raspi4 with usb-audio (3,5 Apple-DAC) = sound stops after ca. 50 minutes
Raspi4 with usb-audio (3,5 no name) = sound stops after ca. 50 minutes
All players with peppyalsa and peppymeter. If I stop/disable peppyservice the issue is present. If I deactivate in settings "ALSA loopback" then are no errors.
At the moment I have no idea how I will find my problem.
removed all unused sounddevices:
config.txt
_sndaloop.conf
I found this threat, but it shows an other issue:
https://moodeaudio.org/forum/showthread.php?tid=157&page=2
Does anybody have an idea?
pi@moode79:~ $ cat /var/log/mpd/log
Feb 22 18:17 : output: Failed to play on "ALSA Default" (alsa): snd_pcm_writei() failed: Broken pipe
Feb 22 18:17 : exception: Failed to open audio output
pi@moode79:~ $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: A [USB-C to 3.5mm Headphone Jack A], device 0: USB Audio [USB Audio]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 1: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 8/8
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 1: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 7/8
config.txt
pi@moode79:~ $ cat /boot/config.txt
[cm4]
otg_mode=1
[pi4]
hdmi_force_hotplug:0=1
hdmi_force_hotplug:1=1
[all]
disable_splash=1
disable_overscan=1
hdmi_drive=2
hdmi_blanking=1
hdmi_force_edid_audio=1
hdmi_force_hotplug=1
#changed
#hdmi_group=0
#add
hdmi_group=2
hdmi_mode=87
hdmi_timings=400 0 100 10 140 1280 10 20 20 2 0 0 0 60 0 43000000 3
display_rotate=3
#end
dtparam=i2c_arm=on
dtparam=i2s=on
#dtparam=audio=on
dtoverlay=disable-wifi
dtoverlay=disable-bt
_sndaloop.conf
i@moode79:~ $ cat /etc/alsa/conf.d/_sndaloop.conf
pcm.!_audioout {
type plug
slave.pcm {
type multi
slaves {
a { channels 2 pcm "plughw:0,0" }
b { channels 2 pcm "pippopeppy" }
bindings {
0 { slave a channel 0 }
1 { slave a channel 1 }
2 { slave b channel 0 }
3 { slave b channel 1 }
ttable [
[ 1 0 1 0 ] # left -> a.left, b.left
[ 0 1 0 1 ] # right -> a.right, b.right
pcm.pippopeppy {
type meter
slave.pcm "hw:Loopback,1"
scopes.0 peppyalsa
pcm_scope.peppyalsa {
type peppyalsa
decay_ms 400
meter "/var/tmp/peppyfifo"
meter_max 100
meter_show 0
pcm_scope_type.peppyalsa {
lib /usr/local/lib/libpeppyalsa.so
Hi harryup,
It could help in the troubleshooting if you try the following command at the begin of the cycle (first minute) in the middle (25th minute) and at the end (before it stops = 48th minute).
The command is: top.
Best regards,
Francesco
Best regards,
Francesco
Can Moode on RPi be used to stream from Sonos?
If so, does someone have experience how to use Sonos via Moode?
Some posts in this thread refer to Sonos but they are clear in unclearness to me.
Hi Francesco,Hi harryup,
Best regards,
Francesco
thank you very much for yout help!
On the results, I can´t find the issue:
Begin:
Middle:
short time bevore break
I have tried several variations of this process with no luck. Is "clearing the queue" the same as removing it from the queue? If not, how do you remove a single station from the queue.When you change a station URL it doesn't update any occurrences of the station in the Queue. Just remove the old station from the Queue and re-add the updated one and you should be all set.
Best regards,
Francesco
found a crazy behavior.
While the music is playing:
[B]Subdevices: 0/1[/B]
Subdevices: 8/8
Subdevices: 7/8
pi@moode79:~ $ lsusb
Bus 002 Device 002: ID 0781:5597 SanDisk Corp. Cruzer Glide 3.0
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 05ac:110a Apple, Inc. USB-C to 3.5mm Headphone Jack Adapter
Bus 001 Device 003: ID 0712:000a WaveShare WaveShare
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
waiting till the issue occours
music stops:
[B]Subdevices: 1/1[/B]
Subdevices: 8/8
Subdevices: 8/8
Crazy, if I press "play" again:
Why does the subdevice change to 1 0 ....really crazy.
O.k. if I stop the music manually the audio Divece change from 0/1 to 1/1 again. I will try to verfy this on the Raspberry with Hifiberry
Sorry for late answer,
I have tryed to replicate the problem and to understand if any problem in memory or CPU lack, but nothing raise.
I Think that if you try to open a thread in the moode Forum, a lot of people should try to help you.
I am very sorry but I have not any other advice.
Best regards,
Francesco
Best regards,
Francesco
I am running 8.2.5 on RPi 4B 4GB model and experiencing EXTREMELY long library update times for a USB connected SSD drive. Library is 140GB with 600ish folders and 7k files. It can take longer than an hour after power up to populate music in the library. This drive is lightning fast on other machines. Looking for any help on diagnosing what may be going on here.
Very odd. It should take maybe a minute or two max for 7K tracks.
What format (flac, mp4, mp3 def, etc) are the audio files?
Which USB port (USB2 or 3)?
Reboot and post the startup log
Code:
moodeutl -l
Thanks for the response Tim. I've been out of town on work but will do some testing and pull the log this weekend.What format (flac, mp4, mp3 def, etc) are the audio files?
90% flac, cues excluded in moode
Storage is on the USB 3
I have a huge library in NAS (almost 3TB both mp3 and flac) which cannot be seen in Moode. Its loading and loading but when it stops all the library is still empty.
If I upload a folder with less data, for instance an artist discograrphy everything seems ok.
Does Moode works flawless with huge libraries or it doesn't worth to try anymore?
Any help please?
Any help please?
@anounak, the symptom "...loading but when it stops all the library is still empty." is almost impossible to troubleshoot without more details about your system.
- moOde version
- Pi model
- Network config
- Number of tracks in collection
- PC Based
- Moode Audio Player for Raspberry Pi
