I just moved from SW Florida. It's gets pretty hot there. I had that old Threshold setup in FL which did not help the air conditioning bill 😬
So about 5 years after he started his review of the XA25, Srajan at 6moons has finally published all of it: https://6moons.com/audioreview_articles/pass-labs-xa25/
Maybe this is what ZM has been waiting for
Srajan writes in English??I much prefer ZM’s Engrish to Srajan’s….🙃
Yup, my intention is, this will be my last build before retirement....sort of a lie, with as many different versions here to play with. That, and already unfinished amps, Sissy boards being altered back to original idea of M25. Then there are boxes of parts for a few others, awaiting cases and power suppliesI’ve been to Palomar, and it was amazing. It was the rockstar of observatories in the Seventies and remained the best until the big multi-mirror arrays were in place. Then there was the Hubble Space Telescope.
If the XA252 (either version) has similar rockstar quality, then it will be well worth the wait.
Previously, I thought this "last amp" would be BBA3, which I have a box for with all the hard parts. XA 252 will only require one Deluxe 5U case instead of two.....back to second AlephJ.
Russellc
Face it, you’re in this ‘til the day you can’t pick up a soldering iron! Like all the rest of us….
I know its a while till I will build my version(s), but I think Russellc is onto something and the reason is the simple two device push-pull output stage. It doesn't matter if its Zen, PASS or anyone else designing the OS, the point is only two Power-FET's per chn (SE vers). Components also do mater, but that is noise related and time domain related and not so much crossover distortion related which is, or should be I should say, superior on amplifiers like this.
The multi OS-FET's used in PASS other amps is not why it possibly sound better or different, that is the frontstage (to a large degree). No matter how one are looking at this, using only one pair per channel (or voltage polarity for the balanced version) will always win, as long as the FET's themselves and the PSU have comparable power delivery while everything else remains fairly similar.
I guess there is room for frontend versions while maintaining the OS if someone like to tinker with that. Like the PASS DIY Front End 2022 or make a fully SuSy version which could be fun and possibly contain hidden gems.. who knows.
Zen Mod: How much of the power supply ripple do you get on the output when the XA252 is configured for SIT or SET? The problem will be due to ripple on the V+ rail modulating the SIT drain voltage relative to ground. My SIT-3X amplifier uses a capacitance multiplier on the V+ rail to solve the problem.
I didn't bother to measure, simply - my T-Bed deliberately being on bad side of proper PSU and wiring ....... and I didn't heard/observe any performance degradation neither with SET nor SIT, vs. full MOS iteration
all that listening on efficient and also sensitive speakers
so, I don't care
so, I don't care
It is pretty simple to measure. Measure Vrms of V+ and Vrms of Out, with grounded input. Maybe some who built one of these amps can respond.
I know it's simple to measure
though, my own XA252 not anymore on T-Bed; what was there, sent to my Bubba Bob and now singing in his Hacienda
preparing slowly to assemble mine as Flying Furnace (powder-coated in meantime) ; most likely Full MOS ...... as also intended to serve as specimen, I know that majority of FiFi aficionados around - will pee solvent in greatest volume, hearing that one
of course will do
I like bragging and showing offffffff
anything, just to confirm
Nice! So much cool factor with that flying furnace prospect.
I could see some red top feathering-looking switch for the on-off. Or a magneto switch-looking thing. Riveted aluminum panel for the top hinged with a lock. XA252 painted with a stencil.
- Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
