Because that the time delay circuit quit simple is. Has every change of value and components influence on the time or function.
By adjusting R/C value you can change start-up delay and with another transistor(gain) you can drive relais with a higher coil current. Try to get about 20 seconds delay, in thar time the tubes are hot enough and output voltage is stable.
There must be differences between SMPS some work perfect and others are bad. But it is no problem to use linear supply.
Yes, this particular SMPS should be avoided at all cost. When I replaced it with a linear supply, Koifarm's preamp sings beautifully!The sound is fantastic.SMPS is bad. I can hear the vibration. I'll try linear.Vunce had a similar problem. Thanks for the great preamp.
With a difference of just a view resistors build and listen to both and tell us which you like most.
Mu-follower has much better psrr then SRPP. Mu-follower can drive lower impedance with same distortion then SRPP.
And there is a difference in harmonics signature. Therefore you must listen which you like best or maybe you dont hear any difference.
Ad simple LCLC filter in DC output to smps and you dont hear any artifacts.
Yours plays better than this
https://www.musicdirect.com/equipment/amplification/preamp/icon-audio-la5-tx-tube-preamp/
Has anybody (in EU) a PCB extra? Just need one, of course, and I checked on (some) sites, 5 is minimum.
Thanks and sorry for interuption, but this sounds like really nice circuit, an I have allready good experience with author (mini me).
T.
T.
How is the tube amp working and sounding with 6DJ8 tube? What changes did you made in this schematic to use with 6DJ8 tube? What B+ voltage are you using?A package arrived in the mail today
Looking forward to building this up and testing it. Plan is to build as SRPP for 6DJ8s
.. dB
I did not used the ecc88 but as good starting/working point i would set Ia on 9mA. R4, R7, R14, R17 = 220 and R5, R15 = 10k/3Watt. B+ = 290V for the mu-followwer topology.
And as SRPP R4, R7, R14, R17 also 220 with B+ = 220V, Ia = 10mA.
Hello Koifarm,
You said, "Ad simple LCLC filter in DC output to smps and you dont hear any artifacts."
Could you please provide me with the details of that LCLC filter? And a BOM if you have it handy.
I certainly would appreciate it.
(Partially genuine Googgle translate, from France 🙂 )
Hello everyone, hello Koifarm (fantastic project). I land late on this thread, and I'm a bit of a noob. I'm thinking of assembling this preamp in not too long - I'm currently on the NuTube B1 from Nelson Pass. ... And since I have Russian tubes to use (6N6P or 6H6P ? memory)... Some newbie's questions 🙂:
Friendly,
Geofdk
- The PCB with the 2 tubes is stereo, and not mono? It does not take 2 pcb and 4 tubes for stereo ?
- Does anyone have a PCB to dispatch? I am very interested! (otherwise I order, JLPCB I think, maybe in one month)
Friendly,
Geofdk
It is stereo as you can see in the first post and I have a (red) stereo board for you. Please send me a PM.
BTW you likely won't experience nasties with linear PSUs as these only need to filter 50Hz mainly and don't create HF/RF by themselves. Choosing SMPS in audio simply is gambling.
- Tubes / Valves
- Universal tube preamp PCB, ECC99/6N6P/ECC88/ECC85/6922/6DJ8 etc. MU follower or SRPP
