A Study of DMLs as a Full Range Speaker
A possiblability?
AlumaComp Aluminum, 30"x36" Archival Painting & Mounting Panel
Not cheap.
Polyethylene core 1/8"
Size : 30" x 36" x 3/16"
Seems heavy, but perhaps not much heavier than 6mm Proplex.
I've got some from having mounted a painting.
You can cut it with a good razor knife.
On my list to try.
@aagas ...just a thought in case the prices or spec are better https://signtradesupplies.co.uk/col...luminium-composite-sign-blanks-standard-sizes
This company produces signage blanks as an Aluminium/EPS/Aluminium composite material. There are many stock sizes and the price looks reasonable. The Aluminium Skin is very thin at 0.21 but the blanks are described as very rigid. I am tempted to test a small sample
Thanks for the info. So, you used the panel as you found it (as a cupboard door) - no cutting done? I was wondering if this panel could be easily cut with a table daw and the correct blade?
I used the panels just as I found them.
One an easily cut the panel, but I'd likely you a track saw rather than a table saw. Less chance of delaminating I think.
Doing so would leave the edging absent and I've come to suspect that the edging matters.
Reactions: twocents
Looks like a great find. I haven't seen anything like this as available in the US. Let us know how it works.
@ Andre Bellwood
Further to my post #8,616
It might be interesting to transfer the 'pistonic' motion to the panel front through a slit in the panel by some sort of a stiff material from the transducer, maybe as shown in this Paddock patent. Red arrow.
The panel doesn't have to be curved as in that patent. By keeping the transducer away from the panel, the panel would not get any distortions from the transducer, or at least be minimalised. The transducer is a piezo in this patent, but it can be any motor. In this patent and in Arcophon, the all sides/edges are held tight, maybe with a soft foam underneath, except the edge(s) that gets the vibrations from the transducer. When we have a flat panel, and with all edges held tight, we can make a slit in the panel to transfer the 'pistonic' motion vibrations to the front. We may not divide the divide the panel in half as in Joppe's video. But we can prepare that area around the joint vertically to get more HF. Just a thought. 🙂
Reactions: Andre Bellwood
@ Andre Bellwood
Is this the Rubanoide tweeter?
Yes, I've been tempted to build something like this with an exciter behind it. But if I did go that far then I think I wouldn't even bother with a panel around it, and just make it long enough to hit at least 150hz on the bottom end, and have space for 4 or 8 exciters on the back... I'd also try to make it open-back and dipolar...
I'm undecided.
I'm undecided.
Just taking an idea off that patent. 🙂
That's more like a modern looking Arcophon.
Link 1,
Link2
Further to my post #8,624
@Andre Bellwood
As @Sandasnickaren made here, #8,102 and here, #8,112, but keep the transducer away from the panel itself. The transducer/exciter held tightly far away, say, on the back of that box, but with only the connector attached to it and to the front of the panel through a slit on the panel. Of course, later the panel can be covered with a nice covering.
I've been experimenting with smaller panels to use in a 2-way setup. I've settled on a 350mm H by 150mm W panel made of a 3.5mm Nomex honeycomb core sandwiched with CF (purchased panel). I will probably crossover around 400Hz because the woofer I'm using has lower distortion below 500Hz. I'm using a MiniDSP 2x4HD for EQ along with REW for measurement. After measurement REW provides a file export of the EQ filter coefficients that load directly into the MiniDSP. The attached response was accomplished in less than 15 minutes (blue is prior to EQ and red is after). I was kind of amazed at how well the panel responded to EQ. I'm still working on the woofer integration. The current panel mounting is a bit crude. I have 3/8" foam strips along the edges and the white duct tape provides a quasi "medial clamp". This is a work in progress but pleased with the results so far. The exciter is a PUI Audio ASX0504-HD-R.
Thanks, Dave
Thanks, Dave
What is the exciter placement?
Thanks, Dave
Excellent
It was already pointed here that the DML by their resonant nature would be suitable for an EQ correction.
Is it possible to see the spectrogram in the wavelet mode 1/6 oct of REW before and after EQ?
Christian
Reactions: lenta and Veleric
Thanks, Dave
Dave,
Did the distortion impove after EQ? I assume the posted distortion results (very good!) are after EQ, is that correct?
Thanks,
Eric
T
Dave,
Thanks,
Eric
The distortion did improve some after EQ in the 1kHz area (see attached). The exciter is mounted essentially in the center of the panel. Attached are the before and after EQ REW spectrograms.
Thanks, Dave
Thanks, Dave
This is amazing indeed!
I find it very interesting indeed that the DSP Eq reduces distortion to such a degree. Is this because of undamped panel resonances that are addressed or controlled by Eq?
I've been very very tempted to use a DSP-based EQ, with a pre-programmed curve embedded in an integrated chip in a pre-amp. And your results make me do a double-take and force me to consider this option very seriously.
Thanks, Dave
I too found that the centre placing of the exciter works well, when the height is near or more than double the width. This places the NXT patents (and others following/copying them) somewhat on its head. Sure, EQ works quite well with thin panels, just like with 'normal' speakers.
Yep Steve... I realise that your 6 mm sheet differs from the 'norm' (presuming there is one)
Using a dome on the corflute lifted the mids/highs and brightened the slightly 'soft' tone...I can't seem to get anyone to try it though 😔..oh well...que sera..(I know you've tried lots of domes.. (but not the coke can one I believe?))
Eucy
I went on a bit of a pub crawl yesterday in London, so am feeling a little delicate today.
But tonight I will force a can of beer down me tonight(hair of the dog) and make one of your domes.
I will attach it to the square fluted ,I think the square flute is called biplex ,not proplex?
I will measure the response and listen, and get back to you.
The domes I used for my thin 1mm panels was to prevent distortions in in the about 3k and 10k areas caused by the exciter problems mentioned in my posts.
I did not design them as a tweeter as such, but they do act as such depending on panel efficiency.
Reactions: moray james
