DIY Front End 2022
What a great contribution to the diy crowd! This may be possibly the new Swiss army knife line stage circuit I was looking for. Many thanks to you Mr Pass for this!
Hmmm, I have a stack of J113s. This looks like it could be a very useful balanced line converter, RIAA or output buffer for eq and active xover.
Any precautions one could take to safeguard the fets in case of input without B+ present? How close do the input fets need to be matched?
if you need to ask, take care to observe presented schm as Black Box;
whatever you want to add, it goes either in front of Black Box, or after Black Box
so, in short - No.
Volume pot goes in front of Black Box
main reason - R1 is defining part of circuit, gain wise and impedance wise; R3 also being important ........... and - in case of resorting to single rail arrangement, there is substantial DC potential across R3
Currently my rails are 22.7V. I thought about doing a CLC with active bridge later that will bring the rails up quite a bit. I guess you get into needing to parallel some more outputs or something.... Would be nice to see a schematic of how to do this properly...
Good possibility!
2SK3557 - JFets do a very good sounding job in two of my WaynesLineStage-variants. But max. voltage rating D-S of 2SK3557 is much lower (15 V max) than J113. Cascoding to the rescue?
No. The J113 can do a really great sounding job! Pretty cheap and available.
Greets
Dirk
This might be beyond my pay grade... Came up with this current sink to replace Q4. Replace Q5 with a KSA1220. Would this work to get more output stage current for a difficult load? Or am I forever banished from the site for blatant ignorance.... 😀
