Big, big TL...
Will it tolerate this?
Ok so, segment 1 is a resonator? Cause do not have an out,
Segment 2 is the actual horn length ? Or TL length cause do not have an increasing area so I not a horn but a transmission line right ?
And in horn resp you modeled as OD ...offset drivers
Why i don't see the dual driver sim cause there are 2 drivers and..what drivers are those?
8" ? 6.5"? Tang Wangs 🙃
I can see small volume but long horn length 3mts. The freq response is wide and smooth DSP processed like 🙂.
Yeah I'm learning just by seeing a lot of hornresp graphs 😁
It’s still the ‘TL‘, but exciting it Further down stream @ the pressure node for 86.4 hz (1 meter out of 3 total ) essentially you get the 1/4 and 3 x 1/4 and bandwidth extends to the 5x 1/4 (cancelation notch) Instead of merely the 3x.
you can still see the ~slight~ ripple in that area of response.
sim in OD mode with 0.1 cm in L12 instead and it’ll have that big nasty cancelation notch @ 86.4 instead of extending to 144hz (5x the Fb)
Reactions: maxolini
Bass reflex is a crime 😝
Reactions: pelanj
A revised version of the design .... This is beginning to look very buildable....
Hey Brian, how are you progressing with developing this - any further updates?
I've had a growing interest in your ODTL work, striking a good balance/compromise of output for the not-so-strong drivers out there.
Really curious to learn of your findings once it's built, and maybe one day I'll try and adopt this specific design (with minor dimension tweaks) for my own use.
Reactions: Booger weldz
