Hello
have searched again.
Anand, if you not have, please read and scroll about from page 310 and you will find needed informations.
Any sucessful builds by experienced members.
Wish ALL a enjoyable XMas.
Super!
Thank you!
Best,
Anand.
I'm afraid that the catalog is much longer and I had to "scan" more than 300 pages. The "search" function doesn't help (maybe due to the way we post to the tread). Anyway.... Do you know (or any else) if anyone has build the pcb in the attached file ? Are there any Gerber files for this ? (Linux user so no MSW programs pls)Hello
These based on Sonal Kunal Board 50 x 50mm.
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4633690
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4635579
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4605857
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4717772
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4718454
Thanks in advance
Elias
Hello Elias,
this is Prasi based Board Rev.1.3 you can see.
Search with Tante Google phrase:
100W Ultimate Fidelity Amplifier FX-8 prasi
showed any results.
Don't know if Prasi has shared gerbers for pcb, but if i remind correct
Terry (still4given) have done a build and measured with oszi.
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4606566
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4610678
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4616788
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4618189
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4622172
Prasi posted here: all
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-5240830
You can upload gerbers to manufacturer https://www.pcbway.com/ or https://jlcpcb.com/
LatFets like EXICON plc.profusion.uk
In VAS/Driver you can use Toshiba TTA/C04 Typ.
I have no access to my own routed Sonal PCB(double sided power traces), because older laptop has hick up
in screen.
I only have my gerbers from pcbway of FH9
showed any results.
in screen.
I rely appreciate your answer. At this moment I'm in page 377 (yes, starting from page 1 some days ago) and I just finished the assembly with my little son's (3,5 y.o.) "help", of his "LEGO car". The way that this thread is unorganized makes me feel dizzy. By the way I'm wandering ... Did someone add a current mirror for the differential input stage ? Not too much trouble I believeHello Elias,
showed any results.
in screen.
Greetings to everybody
Elias
did you figure out the issue?My AX 14 4r7 resistor 2 side bernid out what is tha problam
Hello prasse,
may that points helping a bit.
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/page-422
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-4804111
Same page #8.470 a board.
Somewhere idefixes has showed a F8 board here, but couldn't find it now.
Best Bangla
Best Bangla
two times nice work!AA9MD Integrated I have been using this year. Wonderful!
Your speakers reminds my strongly FOCALAll Apex play for the ear and soul.
Here is a sound from the A40 monoblocks that I showed back.
20210513_150137.jpg - Google Drive
Listen on headphones.
Test 1 - YouTube
Elias
Yes, I tried to approximate the design to them, but the original curves are difficult to achieve.
Here are more details about them.
https://www.diyaudio.com/community/...concepts-is-coincidental.382164/#post-6920236
MId and highs in D'Apolito configuration + Bass. Nice (maybe) but extremely expensive cross-over + the driversYes, I tried to approximate the design to them, but the original curves are difficult to achieve.
Elias
I think FX8 is lateral FET amp and those are GSD pinout not GDS as shown on the layout here. The hexFET version of FX8 using GDS pinout is the FH9 (extra NPN BJT for temp compensation).
The Apex amp directory thread has a lot of links to Gerbers and might be helpful.
https://www.diyaudio.com/community/threads/a-directory-of-apex-audio-amplifiers.292226/
If you follow JohnAudioTech channel read at the description bellow the videos for JAT-501. He had published EVERYTHING for this (very nice according to my taste) TESTED & VERIFIED amplifier, including a single-side-board.Hello everyone
FH9 FH11 is very interesting
But I'm facing problems
1.finding 4.7pF capacitors.
2. Lack of experience with biasing mosfet amplifier. (Little bit fear of losing the mosfet devices😑 ,Ionlyhave6pairs IRFP240/IRFP9240 left)
Otherwise I have no problem building my 6 channel amplifier with FH9 & FH11
Is there any BJT equivalent of FH9 FH11
I have NJW0281G NJW0302G and 2SC5200/2SA1943 in my personal bin.
I have assembled some p3a boards, A23,TDA7294 and LM3886TF and LM1875T.
But not a mosfet amplifier yet.
I can build my 6 channel amplifier with p3a but the pcb layout I have is bigger and takes unnecessary space, so I look all over the diyaudio and find Out, that Alex mm p3a layout is very compact and elegant, but sadly Alex mm didn't published the files for diy home etched pcbs, due to some reasons,
I look back at YouTube and get the Johnaudiotech, which I'm following for last 3 years and more, John have designed and developed a JAT-501 amplifier and published it for free diy purposes, but his pcbs are dual layer layout, although I don't have problems etching the dual layer pcbs at home as long as files are in black and white toner transfer method, it's due to lack of computer at home and lack of experience with Gerber files and their respective programs.
If someone have anything like FH9 FH11 but bjt equivalent. Please share your details.
Needed something compact like this
Or this but bjt equivalent
Elias
LAY6 files are ONLY for windows PC. Gerber is free for everyone's machine (mac, linux, Chrom system, Android,..... name it!). So are you kind enough to upload the Gerber files + schema ?Here is nice PCB Design For APEX A-Class PSU that uses single layer PCB, have CRC snubbler to suppress toroidal ringing, full bridge rectifier and CRC filtering for smooting and PSRR on 50Hz to be minimal, using A-Class from APEX circuit to provide low noise, high PSRR, low impendance out and routed for audio circuit.
NOTE: Rename BRD file extension to LAY6 and open in Sprint-Layout, because diyAudio forum does not allow uploading LAY6 files!
Enyoy!
Elias
I'm following John for long time now, and I do love John videos, especially the LM1875T ,If you follow JohnAudioTech channel read at the description bellow the videos for JAT-501. He had published EVERYTHING for this (very nice according to my taste) TESTED & VERIFIED amplifier, including a single-side-board.
Elias
Thanks for your help anyway 🙂
Prasi have made a very nice and compact stereo amplifier for LM1875T but I can't find this moment the tread to provide you a link. These are all that I have stored in my machine.I'm following John for long time now, and I do love John videos, especially the LM1875T ,
Elias
- 100W Ultimate Fidelity Amplifier
