What's going on with LM3886 availability?
Unfortunate but still.
Put it this way, do you think a 300% increase in price on them is fair considering the scarcity? Especially in your role as a small scale manufacturer/designer using them to produce kits and products?
Wonder if I could trade them for a pair of used console-pull or similar SE tube output transformers 🤔
I did.
Unable to make 50/60W (LM3886) and 25W(TDA2050) Guitar amps I designed a 50W discrete one, still no solution for the 25W ones, although Profusion PLC, which IS trustable, has Taiwan made ones.
So one of these days I´ll pull the trigger on 200 of them, minimum quantity to justify Customs, red tape, bribes, redesign, etc.
Reactions: aditya
Try the TF. I bought both types after I posted the first time. They show already shipped to me. Just tried to order more and the site allowed me to do that, but at the last check told me I had to wait 29 days to order again.
I repaired an "impossible" guitar amp, built around a very poorly implemented LM1875 (or 76, same thing) fed crazy +/-47V rails, boosted by a pair TIP35/36, designer could not see all dials firmly in the red , using one of a pair 1875 free samples, got them straight from TI.
Those were the days 😉
