An illustrated guide to building an F5
Also the distortion graphs need their Y-axis adjusted to show the bottom end of the output.
Like this?
I suggest simplifying the arrangement - from dummy load to autoranger to Focusrite to computer.
Test both the amp board and oscillator with only the autoranger and Focusrite to computer.
Also test the oscillator direct to Focusrite as you can adjust the oscillator output so that you don't overload the Focusrite.
The Focusrite is supposed to be at its lowest distortion when its input level adjustment is at about 11 o'clock.
Sounds like a plan. I just need a longer BNC cable, or I need to rearrange all my stuff (which will be some work).
It's best to minimize the variables. You can add back one piece at a time later.
You can go even lower on the y-axis to show all of the output.
Like this:
That's a lot better, much closer to 0.0002%.
Try it with the Oscillator directly into the Focusrite, and adjust the level at the Oscillator, and set the Focusrite input at about 11 o'clock. You don't need to have the level at 0dB, which may increase the distortion as it may overload the Focusrite. I usually have the level at -10dB or lower.
Akitika Oscillator connected directly to Focusrite Scarlett 2I2. Gain on Focusrite at 11 o'clock.
Oscillator at 500mV and 1V.
Another thing that's odd is that I can't duplicate the measurement in post #2164 no matter what I try, and I think I've tried everything...switching cables, changing inputs, moving equipment around. kind of weird.
The 1V may be overloading the Focusrite a bit.
However the 500mV (-5.34dBV) showing higher distortion than the previous measurement at -10.33dBV does not seem like a good thing to me.
Can the setup and results of post #2164 be repeated? (Edit: Whoops, didn't read the previous post carefully).
I wonder whether something has changed with the oscillator?
Another thing to check is to go into REW's Preferences to see if the setup is still correct.
The 2nd harmonic is very dependent on the gain ratios of the transistors on the positive half vs negative half.
The P ch mosfets routinely have less transconductance than the N's so some 2nd will occur. You can minimize this with device choices, for example with the old Harris devices.
At the same time, the 2nd harmonic would likely be negative phase, so you might choose to just enjoy....
:snail:
Reactions: andynor
