What is the most powerful mono class d amplifier board working at 24v (not +/-) ?
The letters BTL (PBTL) already denote the bridged (or parallel bridged) connection of amplifiers.
If you need power from an autonomous power source, you will have to use a battery from a car or an electric scooter 🙂
You could feed the woofer from a separate amp and the mid/tweeter from another.
You cannot beat these amp boards for the $
Do not believe everything that they write (or read carefully). Everything obeys the laws of physics: voltage, resistance, current, power. Power can be specified at THD >10% and a load of 2 ohms ((For two channels together).
From the reviews on the ZK1002 (they use two 3116 chips for stereo): "... a product with 2 x 100 watts does not actually consume 50 watts, but with a strong signal it will not reach more than 25 watts of sound power, and then distortion and noise ."
The device is not boxed. Power supply not supplied. Can use truck battery 🙂
The point is (and it always was and will be) that with a +27V supply you can get 50W into 6 ohm load TOPS and that if everything works 100% as the theoretical model (meaning you will get less in the real world).
Explained some 20 times in this endless thread.
Reactions: diyMartin
Almost as endless as 'doubling output power by paralleling amps...' ;-)
I'll get my coat.
This board (without op amp) is still the best solution. https://www.ebay.de/itm/401614836334
Clear and crisp sound, powerfull bass and treble and low distortion even at max. I would even recommend 2 of these for stereo, instead of a stereo amplifier board.
Not at all, since it can never supply required 200W RMS into 6 ohm as specified in your own demand.
24V supply?
Think 40W RMS ... period.
Not sure why you keep insisting on TPA3116 boards, which are grossly unsuitable.
Adequate decoupling applies to an end result, and for the money, I seriously doubt you’ll do better. Even if they are using 3118 chips…
Were the reviews from a site like science audio review or whatever that are power supply ignorant?
Maybe someday soon there will be another product available that provides more for less.
IMO some random TPA3250 would be a significant improvement over any TPA3116, the words "clear and crisp" are not the words I would choose to describe a TPA3116 amplifier.
Here is a TPA3250 including powersupply:
https://www.ebay.de/itm/283431830918
Cheaper one without PSU:
https://www.ebay.de/itm/185456859914
But as long as you are happy with what you have there is no reason to upgrade.
Your speakers impedance rises below 150Hz. That is why your 24V amp gets exhausted. The new board may do a little better, but do not expect too much.
With such speakers you should use an amp that puts out clean 200W/4ohm. Such an amp can drive your bass driver, even when it's impedance goes higher than 4 ohm, like 15 ohm around 90 Hz. Such an Amp will need dual 50 Volt at least or a single supply of 50V when it is bridged.
He might try putting a Zobel network on the speakers to try and tame the impedance rise.
Most TPA3255 boards have some sort of op amp already mounted.
Other than that it might be handy to have some sort of tone control unless you use DSP, but to answer your question directly: You do not need an additional pre amp, unless it brings some features to the table that you want to have.
