Acoustic Horn Design – The Easy Way (Ath4)
As for the CBT, you got me thinking and it's pretty easy to implement a source array with each source individually shaded (i.e. level or delay controlled). Now I still need to devise a way to bend the whole structure (forming an arc, as it should be), that shouldn't be difficult. This will be a nice feature to have.
Reactions: 3 users
That’s amazing!!! :)
Hi mabat
if you plan to implement it in the next beta (would be great feature!) just a comment: I did many direct sound sims for line array. Setting low pass filter individually for each tweeter (lower fc the further away from middle; 1st order butterworth) can give very nice cd behaviour. If array is large additionally delaying helps a lot (in groups is sufficient…see keele cbt papers). So what I want to say: please make filter AND delay possible for every driver :)
Curving (complex to build) is not necessary at all if you have some active amp channels to spent!
Reactions: 1 user
This is an example of a Lumped Element Script, you can specify Delay and Filters in here, the LEM section of the ABEC manual explains the parameters available, here there is Tweeter and Woofer but there could easily be a reference to any Element that exists.
Code:
Def_Driving "Driving"
  Value={10^((-25+20)/20)} // -25dBV + 20dB amplifier
  IsRms
Def_Driver "Woofer"
  Re=6.11ohm Le=0.2mH
  //  Rg=0.5ohm
  fre=18.6kHz  ExpoRe=1.633  ExpoLe=0.68
  Mms=3.5g  //Cms=2.349e-3m/N  Rms=0.149Ns/m  Bl=1.573N/A
  fs=100Hz  Qms=4.6  Qes=1.6  //fs=98.6Hz  Qes=1.6
Def_Driver "Tweeter"
  Re=4.8ohm Le=0.05mH
  Mms=0.32g  //Cms=2.349e-3m/N  Rms=0.149Ns/m  Bl=1.573N/A
  fs=500Hz  Qms=4.6  Qes=1.6  //fs=98.6Hz  Qes=1.6
System "S1"
  Driver "Drv1"  Def="Woofer"
    Node=1001=0=2001=0    DrvGroup=1001
    Filter  'F1'
    f0=1.8kHz
    Order=4  LR  Lowpass
    Filter 'F3'
    {b0=0.55;}
RadImp "RadImp Drv1 Front"
    Node=2001  DrvGroup=1001
System "S2"
Driver "Drv2"  Def="Tweeter"
    Node=1002=0=2002=0    DrvGroup=1002
    Filter  'F2'
    f0=1.8kHz
    Order=4  LR  Highpass
    z0=17mm                               // delay between drivers
    Node=2002  DrvGroup=1002
Hi mabat
YMMV, but I think a big part of the reason that the Danley Synergy Horns do that weird thing where you can't even tell where the speaker is located, is because the drivers are located at various depths but the output of the horn is in-phase.
In other words, there's three ways to produce a wavefront that's in phase:
1) The most obvious option is to have a single point source that covers as much bandwidth as possible.
2) Another option is to use a line source and delay the output at the center so that the wavefront is curved (what you are suggesting)
3) The least obvious option is what Danley is doing, which is that the highs, mids and lows radiate from different locations, but the output of the horn is in-phase. Because our ears can detect the location of where speakers are, the net effect is that the sound is in-phase but it sounds like the depth of the soundstage is indeterminate.
Synergy Horns are the only speakers I've ever heard that pull this trick off, it's trippy. If you read Erin's review of the Danley speakers, he mentions it too.
Joined 2004
I think that the output of a properly implemented CBT is in-phase as well. If it's constant directivity both horizontally and vertically, which it certainly has the potential for (within the bandwidth of the array), it can't be otherwise. The question is how low can one get with the array itself. Down to Schroeder would be great, perhaps 300 - 500 Hz is more realistic, I don't know - it will depend on transducers used (without compromising the top end too much).
Joined 2004
beta version available ? :ROFLMAO:
https://www.at-horns.eu/release/ath-beta-221114.zip
Two examples attached. You can export FRD data for the individial array groups and than work with that in any crossover simulator (see array1.txt demo). Or you can also work within ABEC manually on the script level (the most simple is to overwrite individual levels and/or delays in observation.txt).
- No LF source/enclosure support yet.
  • array0.txt
  • array1.txt
