What is TQWT term of the box?I installed SB Acoustics 8" Fullrange(SB20FRPC30-8) in TQWT.
Well-extended bass.
Natural mid and high range with little grating.
High quality throughout the all range, and the performance is above the price.
Do you mind sharing the box design & details, match with tube or transistor PreAmp & Power Amp?
My WhatsApp link: wa.me/+6287782551553, actually I am interested to install in Transmission Line box, if there is any reference to built.
Thank you
Abdi Siregar
Greetings from Indonesia, where the driver SB Acoustic manufactured.
Thank you
Abdi Siregar
👀👇 Tube or transistor doesn't matter. Price doesn't matter. Quality matters. What preamp and amp are you using?
The box is at this URL.
https://sites.google.com/view/low-end-diy-loudspeaker/diy-tqwtml-voigt-pipe-with-damp-duct
Any amp is acceptable.
This is USB-DAC with AMP.
this is a cool thread here! It happend that I couldn't sleep 3 days ago and few minutes after midnight I ordered this speaker 😀
The pair arrived today and I mounted it out of couriosity in the FAST TL of @xrk971 (sorry X) which I built 10 months ago, knowing that it wasn't designed for it. As the xo is a separate unit I can connenct the speaker directly to the amp (the B80 FR is now "dead").
Just to begin at the end - this speakers have the greatest midrange I've ever heard and a gorgeous treble range. I'm shocked
So, next I will mount it into an OB with a 12" Eminence (again, out of couriosity) with an xo (derived from the one of the Manzanita, changed/tweaked).
Any other recommendation? - many thanks in advance!
This hobby is so much fun😀
I would say: for me it sounds better than the B80 in the applications known to me.Thanks für sharing !
Very nice ! 🙂
my question: so the SB-8" has better oder equal highs than the small B80 ?
Oouuups - 😉
It doesn't necessarily mean that the B80 isn't very good or the SB is a world champion.
Btw. I removed some damping material... and here it is, the bass is here too. Funny🙂
Tomorrow I maybe will make some measurements.
Our posts overlapped... that's exactly what I do, I use it fullrange in a TL box. And it's great 👍Play the SB fullrange in the box and see what you get...
One thing: I'm very sensitive to screaming mids, and this speaker is a dream for me. It tells everything (for me).
Nope, "direct drive".OK - I just thought you placed it behind the filter...
Nice!
I'm curious about the box design. Where are the plans?
Btw, from your pic looks like you're driving with some significant amps?
for OB 12" SB bianco ......Our posts overlapped... that's exactly what I do, I use it fullrange in a TL box. And it's great 👍
Yes, here in the forum, XRK's FAST TL-thread. But keep in mind, it is a completely different speaker, designed for two completely other drivers, with dedicated xo. And I only make trials to get a sense how things behave and work, of course with the target to make good speakers 🙂 As is, it is of course not perfect by far - here the measurements. However, for a driver who was simply slapped into any box is not bad.I'm curious about the box design. Plans anywhere?
Yes, I'm aware it won't be optimal for this driver. I'm just curious since you said it sounds surprisingly good.
I bought 2 of these drivers yesterday. I’ll likely give the Demetri enclosure a go as it’s build size, shape and intended room positioning matches with my living arrangements. Exciting stuff. Love hearing all these stellar reviews.
The plans are somewhere in this long thread: https://www.diyaudio.com/community/...-waw-ref-monitor.273524/page-190#post-7169228I'm curious about the box design. Where are the plans?
Significant amps 🙂 it's an M2x finished some days ago https://www.diyaudio.com/community/threads/the-diyaudio-first-watt-m2x.321925/post-7158981 with a separate PSU, built some weeks ago 😀 https://www.diyaudio.com/community/threads/pictures-of-your-diy-pass-amplifier.166784/post-7161513
Nice. Glad to hear it. I like the wide baffle format of the Demetri. Looking forward to seeing how your project goes.
Are you planning on building it exactly as detailed for the Help FR8 driver here on page 2 of this PDF?
I guess so if that’s the version of the 2 that best matches. I might shoot Dave an email and see what he thinks of the match up.Nice. Glad to hear it. I like the wide baffle format of the Demetri. Looking forward to seeing how your project goes.
Hi, I would like to ask, how to deal with the bumps and throughs above 2 kHz?
I made a q&d simulation in XSim (with an Eminence Beta 12" as woofer) and while the bottom would look good (incl. baffle loss in OB, but maybe I have to decrease the bass further), the upper region is still like a rollercoaster (okay, +/- 3-4dB around 92 dB).
Not that I would hear it 😀
- Full Range
- SB Acoustics SB20FRPC30-8 (8" Fullrange Cheap Monster II)
