You said no, but then supported my response and then switched topics. I am just wanting an accurate system ( aka low distortion), not one that sounds good.But ultimately does it sound any better, more realistic or more enjoyable?
Adaption is very real, if you listen to something in a flawed way for a very long time, when presented with a more accurate version you may dislike it because it sounds wrong to you.
A very good reason to aim for higher accuracy...even if you don't like it at first, youll adapt. Still, my discussion was focused on what leads to higher accuracy in the room. You keep jumping topics since you have no win on this one. I already agree that preference exist for many.
Cant wait for your response that has nothing to do with signal accuracy in the room....☺️
A slippery slope, in the video I posted with Earl, Erin stated a preference for distortion in some listeners. Still, these are all side notes
"I also share John Meyer's philosophy of trying to be as technically correct as possible, whether doing so appears to be audible or not." - I second that motion. I just wanted to make sure that it was known how to achieve a more technically accurate reproduction, in a room; directivity, or other things that increase direct sound, along with the direct sound being free of distortion as well. Even if a newer method will come along and be deemed superior, to which, I or we will hold as the new standard. Monitoring IR reproduction in the room is not a bad practice, and is, I believe, the most practiced approach to judging system accuracy, in room, at a given listening point. Then theres the test of Square wave reproduction. Who knows whats the newest on the horizon is....
Yes there can be a preference for distortion. That data's been shown.
In my own experience it's often heard as extra details or special effects that may be perceived in a positive way. I'm got going to get into all the flowery adjectives that audiophiles and musicians describe it.
Yes I've watched that video. And I know Earl's position for the last decade or so. I've already stated mine to him most recently:
Is what you're positing that more directive speakers are more truthful? Or better?
I discussed both this previously. In short- it remains to be seen...
https://www.diyaudio.com/community/...istortion-speaker-drivers.294787/post-7094796
My last sentence for those who can't be bothered
"more research needs to be done on non-linear distortion and directivity"
Let's go back to Exploring Purifi Woofer Speaker Builds
I have not looked at this thread in about 3 weeks... what the hell happened? a ****splosion?
So has anyone assessed the subjective midrange sound quality of the PTT6.5X-NAA series to the dedicated midrange PTT6.5 M-NFA series ?
j.
Hey Jim!
I'm fortunate enough to have all three in standard 4 ohms-
PTT6.5X-NAA (R), PTT6.5X-NFC (L) and PTT 6.5M-NFA (not shown):
https://www.diyaudio.com/community/...nts-purifi-and-scan-speak.390316/post-7155239
But haven't done a subjective midrange sound quality comparison. What do you propose?
I'm not trying to win, only to help you, in general I seem to be failing at that specific task.You keep jumping topics since you have no win on this one.
What is happening here... I made simple model of white spk8 with ptt4.0 alu and modified waveguide 🙂 It seems perfect for desktop speaker.
I am not sure. I have never gotten much value from listening to drivers in isolation, but some people seem to be able to discern quite a bit from just listening to a woofer or a tweeter.But haven't done a subjective midrange sound quality comparison. What do you propose?
I am considering an active 3-way application with a 6.5 purifi driver and a waveguide tweeter. The 6.5 would operate from 200 to 2k, more or less... I am trying to understand the pros and cons of using the midrange driver with fiber diaphragm versus the midwoofer with aluminum diaphragm. Both look really good. I am just gathering information at this point.
I faced the same question myself and opted for the 6.5 Aluminium, a few reasons whether they help you or not. When notched the Aluminium has the most consistent overall response across all axes and the lowest distortion levels. It is more flexible if I decide to use it in a two way, and it just looks way better to me, I really can't get on with the look of the paper cone. I didn't like what happened to the Mid version higher in frequency, it gets quite a bit wilder higher up. I see consistently in peoples impressions that drivers with extra output beyond the useable bandwidth, particularly that aren't well controlled aren't preferred as much.
The mid does have the higher sensitivity and if that can be used in the overall design that is something to consider. My view was that the Aluminium was so linear that I could just pump more power into it as a mid in an active system and not really lose anything. There are some hints in Troels Purifi Tower build that there is something better about the mid version for pure midrange, but the datasheet from the Aluminium lists uncompromised midrange too 🙂
It's always nice to hear peoples impressions of the sound but the implementation matters so much in the overall result I can only imagine that the comparisons would be more apple to orange.
well all in relation with tweeter phase integration and type of xo.... sure ale put more details ,my ss 9800 is wonderful (smooth) but for mid ...btw all depend room end system for final choice
Then I must not use the words "quality" it seems, but its a quick fix;
For those who want an accurate recreation of the signal, A higher directivity will help get you there over a wide dispersion, in a room...
The signal received at the ear will be of higher accuracy to the source with higher directivity or higher Direct energy (which is what higher directivity creates anyway).
The room really messes with what comes out of the speaker....so even if what comes out of the speaker isn't accurate, the room will make it even less accurate.
There's a difference between what one prefers to hear and what the signal says you should hear.
My personal idea of a quality signal is one that is high Accuracy.....Others may prefer more distortion
So now we can say that the 15" creates a more accurate signal. in a room, then a small midrange that remains omni for much more of its passband, in particular in a small untreated room. I can't imagine that @nicoch58 is going to be happy with this reiteration of what I already was saying.
How can we talk about achieving accuracy in an untreated (or untreated small) room? Want to open up a new thread on accuracy?
Even on your own thread, you were the only one that thought a beaming speaker would be the key to success. The rest were trying to make you think a little harder.
please avoid offtopicHow can we talk about achieving accuracy in an untreated (or untreated small) room? Want to open up a new thread on accuracy?
I agree.
From shifu:
http://www.zaphaudio.com/evaluation.html
Written over 15 years ago, and most of it still stands today.
I think tktran303 is cooking something up. I was going to get a pair, but funds tightened up this year.
@jcga has with 8Ohm version he described hereAnyone received and built with the 8" PTT8.0X04-NAB-02
https://www.diyaudio.com/community/...ifi-woofer-speaker-builds.352063/post-7017710
Hi Lars,
The new PTT4.0X04-NAC-03 have very cool bandwidth. I also noticed that the suspension kms(x) seems more linear than older PTT4.0 drivers. Is the suspension upgraded in this model?
Strange that Voice coil magazine were talking about not able to push more on the 4 inch model due to mechanical issues. The klippel measurements seems limited to relatively small range. I wonder if the suspension update is true, will it improve this regard? Or was it just an one-off issue?
Thanks!
Thanks!
hi,
We have improved our own proprietary analyser and thus makes the Kms(x) curves more consistent than before. newer data sheet curves are therefore generally nicer. We will update all older data sheets over time.
The Klippel analyser (we have one also) seems to be challenged when resolving our very flat Bl(x) curves. In the Klippel analyser the Kms and Bl curve estimation is tightly coupled so that a wrong bl curve causes a wrong Kms curve. Our analyser is first estimating Bl(x) and then independently estimating Kms(x) all thanks to continuous use of the data from the displacement laser (Klippel analyser is not using the laser during LSI).
The new alu 4” uses the same spider but the cone assembly is from another vendor (specialised in alu cones of course). I would not expect any systematic differences from the paper version.
Note also that Kms(x) is the nonlinearity to worry the least about since it’s contribution to IMD is minimal unlike Bl(x).
cheers
Lars
cheers
Lars
look nice nano speakers with a 19 or something planar, perfect for my pc with a ACAmini!Hi Lars,
Thanks!
- Exploring Purifi Woofer Speaker Builds
